Technical Mercury flathead cam specs
Discussion in 'The Hokey Ass Message Board' started by tubman, Jan 30, 2023.
  1. tubman
    tubman
    Does anyone out there have the specifications for an "EAC" ('53-'53) Mercury cam shaft? The "Tilden Cam Technologies" chart gives lifts of .307 and .337 respectively for "8BA" and "8CM" camshafts, and someone posted on "The Ford Barn" that an EAB cam was .330" lift. I have been quite satisfied with the performance of an "8CM" I'm currently running and wonder if the "EAC" might even be a little better.
  2. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Having bought, sold,traded over 50 flathead engines over a 60 year “fascinated love affair” I have HAD numerous cams with the 307 lift but have never heard or seen the cams u stated as being 337 lift. Flatheads Forever!! 0253844C-D435-4E70-9B1E-FD36A2A5D97F.jpeg 5D3673D8-39D9-4015-AEC6-035A0F2A847D.jpeg 3A75A69F-49E3-408A-9D21-97A35AEACEF5.jpeg 7AA2A8AF-5761-4B03-986D-E27D608325D5.jpeg D5286583-F632-476B-A756-A86CE25EE4AA.jpeg
  3. flatjack
    flatjack
    Going through my cams, I have 8BA, EAB, EA, 1CM and 8CM. I have not seen one stamped EAC.
    going
  4. tubman
    tubman
    Given the similarity between Ford's and Merc's of the era, perhaps the Merc's also use the "EAB" cam.
    You don't have a lift figure for the "1CM", do you? Just curious.
  5. flatjack
    flatjack
    Checked 2 cams, both were .329 lift.
  6. tubman
    tubman
