Hot Rods Mercury Pressure Plate Question.
Discussion in 'The Hokey Ass Message Board' started by 51 mercules, Oct 31, 2025.
  1. 51 mercules
    51 mercules
    I acquired a Cragar adapter for a Flathead Ford Trans to a SBC. I was told I needed a Borg & Beck 988 1949-51 Mercury pressure plate. They seem difficult to find? I came across an add on another website listing a 10" pressure plate which is #1310? It's listed on the add for an International and Mack truck? Seller doesn't know if it will anything else?Kind of looks like a merc pressure plate? What do you guys think? Wanted an opinion before I pull the trigger. pp2.jpg Thank you!
  2. Fordors
    Fordors
    The photo credit goes to @hotrodA , the picture was on one of his posts.
    The number, 1310, in the photo might look odd, but Fort Wayne may have restamped the clutch cover.
    51 mercules likes this.
  3. 19Fordy
    19Fordy
    Here are some photos of an original Borg&Beck 1949-51 Merc. manual transmission 10 in pressure plate #1310.
    It looks like someone restamped yours to 1320.
  4. 42merc
    42merc
    looking at the pic, looks right.
    If the fingers are too long a bit of grinding will let them work.
    I HAVE done this in the past. Grind just enough to clear the bearing retainer.
  5. 51 mercules
    51 mercules
  6. 51 mercules
    51 mercules
    Thanks for the pic's and measurements!
  7. 51 mercules
    51 mercules
    Thank you!
  8. 51 mercules
    51 mercules
    I took a chance and bought the pressure plate that was listed for a Mack or International Harvester. Got it today and it fit perfectly on a 153 tooth flywheel that a buddy gave to me. 20251108_140251.jpg 20251108_140408.jpg
    alanp561, Fordors and anthony myrick like this.
  9. Cool beans
    The stuff I looked up said 988-1310 was the merc PP used 49-early 51.
  10. 19Fordy
    19Fordy
    That's great news and will help others.
    alanp561 and 51 mercules like this.
  11. 51 mercules
    51 mercules
    This is what how the pressure plate was advertised: Clutch Pressure Plate 1310 10" 1941-1949 IHC Truck 1944-1950 Mack. not sure if it was mislabeled or really fits these other vehicles?
  12. big duece
    big duece
    from kansas
    Double check your fit on the bearing retainer/ pp fingers. There is another Merc pp that looks the same, but the fingers are longer for the later, smaller trans input spline. Looks like the original number was 1319, and was scratched out. That was 51-53 Merc with the 1 1/8" input spline. They could have put the short fingers in making it a 1310.
    left is from an early 51 merc. 988
    The right is a late 51 merc. 1319. The arms are slightly longer
  14. big duece
    big duece
    from kansas
    I see the 3 fingers on yours is part # 4079, which is the same as the "19forty" picture he posted of a straight removal of a 1310. Wonder where a guy could find those parts separately. I have a b&b plate, identical to Merc but has wrong "arms". The part # on mine denotes Chrysler I believe.
  15. 51 mercules
    51 mercules
  16. 51 mercules
    51 mercules
    Thank you for all the pics and info.My pressure plate does look like it was restarted with 1310 and another number scratched off.But my pressure plate measurements match what 19Fordy posted.I should be good! 20251109_161910.jpg
    alanp561, bchctybob and big duece like this.
  17. Fordors
    Fordors
    If there is a rebuilder near your location they may possibly have those fingers available and also they have what’s needed to install them effortlessly.
  18. 51 mercules
    51 mercules
    Thanks for the pic's.
    anthony myrick likes this.
  19. vtwhead
    vtwhead
    I am in the middle of sorting out this 1310 fitment for a friend. Anyone got the measurement for the height of the fingers setting on a flat surface (not installed) and the spread of the fingers to allow the large Ford TOB????
    I found a Dodge plate that might work but I need to verify some dimensions first before pulling the trigger.
  20. choptop4
    choptop4
    20251117_101726.jpg I have been looking for a 1310 , then this came up for sale. 40 ford , drilled flywheel, wilcap adapter. All for less than a 1310.
    Thanks Josh !
  21. vtwhead
    vtwhead
    I think that pressure plate is the long B&B unit with the centrifugal weights that provide a bit more clamping pressure when the rpm's are up from what I have read.
    Big Al and bchctybob like this.
  22. big duece
    big duece
    from kansas
    Bump for vtwhead, also like to know the finger height, and spring pressures at particular heights.
    IMG_9774.jpeg finger height bolted to the PP with disc
    Inside-outside 11 5/8
    51 mercules, Algoma56 and big duece like this.
  24. For those of you who think or have been told that the 49-51 Merc PP is the same, that information is Wrong. 49-50 is the same. 51 for Merc is a one-year deal. Instead of the 2-piece bellhousing and Early 48 and back style Ford gearbox Henry changed it up to accept the new 49 and up Ford Car trans. That means a 4-bolt gear box, 1 piece bellhousing and the much smaller front bearing retainer accepting the smaller T H bearing collar, thus the shorter 3 fingers on the PP. Then know that the 51 Merc bellhousing is a 1 year only unit being it still uses the 48 and earlier clutch release fork system, not the new standard Fork that enters through the big opening that became standard in Ford Cars. Clear as Mud, right?
    seb fontana, 51 mercules and Algoma56 like this.
  25. Pulled both of these out of 51 mercs
    Thats all I know
  26. big duece
    big duece
    from kansas
    I thought there was a transition in '51, denoting a early and late '51.
  27. Fordors
    Fordors
    I had read more than once that '51 Mercury's used two different pressure plates and clutch discs. Early production used the larger diameter throw out bearing with a transmission that had a small bell housing cast integrally with the trans case and the later cars had the smaller t/o bearing used with the four bolt trans that Ford adopted and used through the '50' and '60's.
    Edit- here’s a photo that @KRUZIN62 had posted of the early ‘51 Merc transmission.
  28.
  29. big duece
    big duece
    from kansas
    No rebuilders near me, I did email Fort Wayne Clutch and they said the would sell me the correct fingers for the 50 Merc application, just need to some specs to set the fingers up.
  30. F-head
    F-head
    I have a rusty but rebuildable 1310 for $100 shipped if anyone is looking IMG_9292.png
    Algoma56 likes this.
