Technical mercury wheels
Discussion in 'Traditional Hot Rods' started by wyattplains, Jun 19, 2016.
Tags:
  1. mercury wheels
    0 vote(s)
    0.0%
  2. wheels
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. wyattplains
    wyattplains
    looking for 14 inch mercury wheels to fit my 1951 mercury....hoping there might be some later models that would be easier to find....my reasoning is i have a nice set of 1952 mercury hubcabs i would like to use.......any help appreciated.....
  2. Squablow
    Squablow
    '52 Mercury hubcaps fit 15" wheels, not 14" wheels. You may be measuring them wrong. '52 Mercury caps (***uming you're talking about full wheelcovers here, not the "dog dish" style center caps) will snap onto a stock '51 Mercury wheel.
  3. Mr48chev
    Stock 51 Merc bolt pattern is 5 on 5-1/2 52 and later is 5 on 4-1/2 same as 49 and up Ford.
    If you truly need a 14 inch wheel you will probably have to hit the aftermarket as I don't know of a 5 on 5-1/2 x 14 inch wheel of any kind.
    You would have to hunt for 57/58 or 59 Chrysler Imperial wheels to find that bolt pattern in a 14. Probably cheaper to see if one of the aftermarket outfits will make a set.
    Scroll down the page. http://www.carnut.com/specs/gen/chry50.html
    s
    lothiandon1940 likes this.
  4. k9racer
    k9racer
    If you can not find the imperial wheels. Drill out your merc centers and find some donor outer shells and weld them . Or contact wheel guy here on the board and he can fix you up with what you need.
  5. chrisntx
    chrisntx
    from Texas .
    Good luck with that. if it was possible some of us would have done it long ago
  6. gas pumper
    gas pumper
    There were postal Jeeps with 14 inch 5X5 1/2 bolt pattern
    LOU WELLS likes this.
  7. Atwater Mike
    Atwater Mike
    '62 Merc caps? Huh? Possible...
    Also, just for drill: '56 Mercs had 5 0n 5" pattern...same as Cad, Buick, Pontiac, Olds...
  8. stillrunners
    stillrunners
    from dallas
    X2 on the Imperial wheels....also easy way to lower an early Ford/Merc....
