Meryn Cadell and the VEry GAy engine...
Discussion in 'The Hokey Ass Message Board' started by Fat Hack, Jun 14, 2004.
  1. DIRTYT
    DIRTYT
    from Warren,MI
    well i keep it above 100 on the way in and to work its a 85 mile round trip every day. and at those speeds and my my foot to the flor at every stop light. i get around 36mpg!! [​IMG] it will get better if i stay at like 80 so its outa the "vtec" lobes on the cam
    Bryan
  2. OK-I just got back.......looks like its gonna happen like this?.....Hack and Dirty on a road trip in the metrocar comin to my place to pick up the engine and trans.you dont need no stinkin truck!- Ill spring for the dinner here in Elmer- so thats a small help!
    Hack -I know swaps and Im saying this trans and motor will fit in there with room to roll it over and back up again.
    Then it will fall out thru the bottom hole left by the 216 unless its bolted in securely.!
    it is a 2.8 s10 trans[3 gears] no overdrive.Ive put 400 turbos in these cars-
    the engine mounts towards the front on each side.....the tail shaft mount will be about two inches behind the stock mount holes in 49 crossmember[4 bolt plate-two for trans and two for stock hole in xmember] .no need to change intake......if the thought of this motor in your car isnt weird enough then why in th hell would a long hose from the rear of intak to top outlet of radiator offend anybody! [​IMG] DONT FIX WHAT IS RUNNING!!!!!THANKS everybody for helping a friend and Hack -let me know when you guys are comin for sure. [​IMG]
  3. Upchuck
    Upchuck
    from Canada BC
    this new engine in no way dediscofies it either Hack [​IMG]
    they see the dingleballs and the crispness of the tunes blaring from the ole 8 track on them 4 watt radio shack speakers and the bright fuzzy fake fur fadeing in the sun on the dash and the contact cement lifting in the corners there is just no way it could be mistaken for anything but your Hackmobile aka the discomobile [​IMG]
  4. DIRTYT
    DIRTYT
    from Warren,MI
    yahooo 38 bucks and some change so far in paypal. thats gas money. now we just need those cookies!!! [​IMG]
    Bryan
  5. HotRodDrummer
    HotRodDrummer
    KB!!??? you willing to take your torch down?
    Is There AIR avaible?
    KB?? you in on helping?? I realize you have a plate full...
    How bout I pick you up on the way..hell I'll take my torches and such..
  6. Hack- just do a request -driving directions to here on MAPQUEST.COM
    my phone numbers are: 660-825-4572 home and 4080 shop
    [​IMG] this drivetrain is good and been stored inside the whole time!
  7. HotRodDrummer
    HotRodDrummer
    Hell... I'll bring the Plasma cutter if there is air...which I doubt...
    just in case [​IMG]
  8. DIRTYT
    DIRTYT
    from Warren,MI
    and then we trash my car? hehe [​IMG]
    Bryan
  9. HotRodDrummer
    HotRodDrummer
    What does dirtyt have for a "brand new welder"??? 110v?
    that would more than likily work for a trans. cover (never used 110v, I'm sure if it is turned up anuff! [​IMG]
  10. DIRTYT
    DIRTYT
    from Warren,MI
    o dont insult my 110 welder. its the king **** snap on one! can weld god damn near any thing in a single p***! i was burning thru a old brake rotor with it the other day when i was messing around. and my boss just payed for 2 11 lbs spools of .030 wire non flux core of course. it can handle any thing the chevy will spit at us! o yea and it is "brand new" just bought it like 2 months ago
  11. Upchuck
    Upchuck
    from Canada BC
    do you got a dryer or stove plug in? you can make up a 220 extension cord out of some #8 wire if it comes to that and someone has the wire and ends?
    my little shack is a 100' or so from the house so thats what I do and it seems to work pretty good
  12. HotRodDrummer
    HotRodDrummer
    sorry hack... don't know much about bolting **** together..
    Bring your welder dirtyt....I will bring the plasma!!!
    I have to sell some to get there.....and bowling green!!
    25 bucks a pop!! plasma that is [​IMG] [​IMG]
    I'll bring some water filters making sure the plas will work... [​IMG]
  13. remember guys -this motors so little you can use a heater core for a radiator! [​IMG]
  14. HotRodDrummer
    HotRodDrummer
    so now you need a shroud(SP?) TOO!! [​IMG]
  15. not any of my bussiness Hack-but I recommend installin this thing close to the radiator/that helps with the aforementioned FREAKtop hose deal and also will make the space for the trans tailshaft work out better.
    Maybe even allow for the stock trans tunnel cover to still work./not to mention the MORE weight appied to the front suspension would be a welcome [​IMG] addition.OOHHHHH
    Most importantly Denise told me about the box of cookies [for me]------Dont Bogeart dem cookies or yo'all dies...... [​IMG]
  16. hotrodladycrusr
    hotrodladycrusr
    [ QUOTE ]
    [/ QUOTE ]
    "bogeart".....OMG, I haven't heard that term in YEARS! [​IMG]
    Don't worry sweetheart, I'll put your cookies under lock and key and send the key to you ahead of time. Besides, just don't give them the engine and trans till they give you the cookies....kinda like a ransome thing. [​IMG]
  17. Remember I own this town.......Ill have my enforcers here at the shop........its the weekend and they are ***** -so dont set them off......[or turn your back] [​IMG]
  18. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Alright HACK, Even though I kinda feel like a just bought recovering crack addict a rock cuz' he's havin a rough night, I just paypalled $20 to Bryan. Spend it wisely! [​IMG]
  19. thanks everyone-[send a twenty to pay pal][......where we at on road trip contributions, so far Brian?[-[dirtyT]
    [​IMG] Cmon-shake loose for a good cause!
  20. ray
    ray
    from colorado
    hack dude, its SOP to cut out the center of the trans crossmember when putting slushboxes in them chebbys. you just gotta drop the mount about two inches or so. if you want, i can get in on this charity a little...i got the mount i cut out of mine, going to a custom made crossmember, it ain't much of a mount, but it's what you get with the store bought motor mount kits, still got bits of my old crossmember attached, no extra "cost"! if you want it, i'll throw it in the mail tomorrow for ya! save you a bit of hacksawing. iffin you want it hit up my pm with your addy.
  21. No Hack- those are my "neighbors" on either side of my shop downtown.....OH-I checked the 2.8 has a conventional REAR SUMP PAN........
  22. DIRTYT
    DIRTYT
    from Warren,MI
    good morning.. why is this on page 39 and ****! just looked at paypal. 95 bucks and 40 cents. after paypal takes there share out. ok off to work and bttt with this. [​IMG]
    Bryan
  23. dixiedog
    dixiedog
    You got 20 skins from me Hack!! Thanks for all the help with my junk!!
  24. BACK UP TOP-Cmon guys wheres that HAMBR helpful spirit,,,,,,,send a twenty to DirtyT's paypal...[.it's listed in this post somewhere]........
    Theyll need the gas money for this road trip! [​IMG]
  25. Upchuck
    Upchuck
    from Canada BC
    DirtyT's paypal info
    [ QUOTE ]
    o yea paypal info is yalpal@aol.com
    [/ QUOTE ]
  26. nor cal nic
    nor cal nic
    brilliant ... you are my MUSE OF MOTORS(tm)...
    nic
  27. Slide
    Slide
    FH- FWIW, I have a T350 in my 52...no cutting of the crossmember or "m***aging" the trans tunnel. (I did have to remove some undercoating for clearance, tho!) Thing is, the trans is hard-mounted sans OEM trans mount. (Engine has the rubber mounts.) There is just a flat 4-hole plate like someone else described. 2 holes for where the mount would normally go into the T350. Other 2 holes are threaded for some 7/16 bolts. This is where you bolt the plate itself to the 49's original trans mount holes in the crossmember. The fit is tight...about 0.001" clearance between top of ****** and bottom of tunnel, but it fits!
  28. Hackerbilt
    Hackerbilt
    2.8's don't use the same ****** as a small block Chevy.
    The bellhousing is smaller and uses a smaller torque converter.
    Vega converters WILL fit a common T350...so the Vega automatic is bigger in the bellhousing and possibly bigger in the main body as well.
    The S10 must use one of those T200 ******s mentioned earlier!
    I think your in luck Hackmeister!!! [​IMG]
    Bill
  29. You'll still have $14 left after purchasing your Six Dollar Burger, Hack.
    73.7 grams of greasy deliciousness, MMMmmmmmm mm!
  30. Yeah Hack I think you can make this swap happen.
    I believe it will also pull the 49 fair too as it was in a 1981 CITATION originally.
    Cant be much difference in weight there.Ill look up any "peripherals"[thats parts in english] that goes with this engine..........I am glad to see it put to a semi sane use now.
    CAUSE-,I was gonna install it on a two wheel.........M/C that is [​IMG]
    Now I get to LIVE and you get to drive! [​IMG] [​IMG] [​IMG]
