Metal Flake: suspend or dry?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Apr 1, 2013.
  1. Suspend flake in clear
    88.2%
  2. Dry shoot flake on
    11.8%
  1. oldrelics
    oldrelics
    from Calgary
    What is the most prefered method of flaking? Suspend in clear or blow it on dry. What are the pros and cons of both methods?
    What size tips are needed for suspension?
  2. I always suspend it in clear.
    Any time I have tried dry flake, it has resulted in
    flake everywhere except the surface I wanted it on.
  3. pbr40
    pbr40
    from NW Indiana
    With dry I did my roof in small flake and it was a terrible!!! It was more like metallic! It you use bigger flake you might be fine.
  4. oldrelics
    oldrelics
    from Calgary
    Yea, I tried dry on a dash, my impression is that all the flake lays flat and isn't as dimensional as it should be....
  5. zjerry
    zjerry
    I never tried dry.
  6. willys1
    willys1
    from South Ga
    Me too:)
  7. Midwest Rodder
    Midwest Rodder
    I did the interior of my 48f1 in Roth Monster flake. Blew it on with the flake buster. Did an excellent job and it looks exactly the way I imagined it but the flake did get every where in the shop and with the Monster flake you have to burry it in a **** load of clear. If i remember right we sprayed 8 coats of clear on the dash and 6 on the doors and jams.
  8. oldrelics
    oldrelics
    from Calgary
    so, a dumb question: If you use a gravity feed HVLP wont all the flake sink down into the gun and plug it?
  9. BadLuck
    BadLuck
    i threw a couple nuts in the can.. and "shake and spray"! My buddy mixed me some "binder" which was paint with no color pigment.. that way you could spray more coats without building up too many layers of clear spraying the flake.. then AGAIN when you clear over the flake. Worked great on my roof and dash.. good luck!
