metal workers...ck this out
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 26, 2003.
  1. sawzall
    sawzall
    yes.. you could use a hyd cylinder.. I have a friend who was using his portapower to drive a cylinder which raised / lowered his bottom wheel.. he did have a "pressure" gauge as well (if I remember correctly) however
    the question as to WHY arizes.. an threaded shaft is alot easier.
    I use my wheel for shaping.. as well as planishing.. it depends on the project material and my at***ude.. often the "hammer" gets it done quicker.
  2. enjenjo
    enjenjo
    from swanton oh
  3. John_Kelly
    John_Kelly
    In addition to Ron Covell, check out Kerry Pinkerton's stuff:
    www.wheelingmachines.com
    for high quality parts and complete machines.
    www.metalcrafttools.com
    is another good place to buy.
    Paul, I have an english wheel with a rectangular frame for stiffness and the most efficient use of material I could come up with. You are welcome to come by and try it out. I am about 3 hours away from you on the coast. Lessons available as well.
    John www.ghiaspecialties.com
  4. pimpin paint
    pimpin paint
    from so cal
    Hey,
    I beleve that the Tinman (Kent White) sells, or use to sell lower anvils
    in semi finished form for cheaper than finished ones. With these and the
    steel from a local source, I'd think a guy could put together a better wheel
    for much less than the toy wheels are commanding. Of any of the bench top
    wheels that I've ever used, the best part was that I didn't own them! Just
    ok for thin sheet and aluminum, but worthless as mule *** in real steel, and
    forget about wheelin through any welds.
    S****ey Devils C.C.
  5. Unkl Ian
    Unkl Ian
    The Hard Chrome shafts I used in the lower adjusters were actually
    off cuts from making hydraulic cylinders.Machining details in my
    english wheel album on www.allshops.org
    To use a hydraulic cylinder as a lower adjuster,you need a spring return cylinder,an easy way to generate controlable pressure,and some way to
    stop the lower yoke from rotating.If you have to pay for the hydraulics,
    I would not bother.
