Metal workers question
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 26, 2013.
  1. Roothawg
    Roothawg
    I would like to build a set dies for my HF bead roller. I wanted to experiment with the Nylon step dies used for embossing panels. Just curious on the difference in size between the two dies. How much smaller is the lower die?
    Also, what is the hardness of the nylon stock you start with?
    Thanks
    Root
  2. lucky-13
    lucky-13
    from Sacramento
    your going to want to use a material that is harder then what your rolling or your not going to get a clean edge in my past tries
  3. Roothawg
    Roothawg
    Maybe the nylon was being used on aluminum?
  4. lucky-13
    lucky-13
    from Sacramento
    maybe but with aluminum you get so much stretching that you want to have a sharp edge for a step i would try to either make or buy a set made of tool steel
  5. Roothawg
    Roothawg
    I have seen them built out of both aluminum and delron. Fiddy Four was building some. I guess I need to talk to him and see what he says.
  6. Da Tinman
    Da Tinman
    Dies should be the same size that way they both run at the same speed.
    NO SHARP EDGES OR CORNERS. simply put those sharp edges and crease create a stress riser in the material your running thru it. Not that big a deal on steel but on aluminum any high frequency vibrations will cause cracks and frays along that sharp edge.
    I use my delrin steps on everything up to 16 gauge steel. Been using the same set for 5+ years with no ill effects.
    One bit of caution on the "plastic" rolls. don't drop them, they get dinged up in a hurry that way.
    Talk to Fids and PM your phone number with a good time to call and I'll be glad to help too.
  7. Root, listen to DaTinman, Jay knows his **** and Fiddy can make you dies. Vagabond love ;)
  8. David Totten
    David Totten
    hoosier profiles makes nice ones also. check his website.
  9. bct
    bct
    I build my own . I bought a bar of 2" round and another 2.25 and 2.5 .....lots of work machining the stock down on the male profile. later I realized that I could make most of the needed profiles in pieces and dowel them together. like for a 1/4" bead I used two slabs of 2" and a disc of 1/4" plate 2.5" round sandwiched in between and pinned....
  10. nxcess
    nxcess
    from Mesa, AZ
    I have never tried nylon type dies, but the dies need to be the same dia.
  11. Roothawg
    Roothawg
