Metallurgy question
Discussion in 'The Hokey Ass Message Board' started by REJ, May 10, 2006.
  1. REJ
    REJ
    from FLA
    Does anyone know what the front sway bar on an s-10 is made of?
    Is it a material that I can weld on? I need a piece of 1" shaft and this is perfect if I can use it.
  2. Unkl Ian
    Unkl Ian
    It's probably 4130,4140, or similar.
    Yes,it can be welded,
    BUT you risk the welds being brittle depending on how fast it cools.
  3. AllSteel34
    AllSteel34
    Probably 8620 or a similar spring steel. Spring steel does not like to be welded. It loses its temper.
    Chris
  4. squirrel
    what is the shaft gonna be used for?
  5. el gringo
    el gringo
    from Chicago
    As a metallurgist (seriously), I would strongly recommend against welding on spring steel.
  6. peanut
    peanut
    i have tig welded a swaybar before. and it worked.
  7. 38Chevy454
    38Chevy454
    From the HAMB metallurgist. A sway bar is most likely not heat treated. Also it is probably a low-alloy steel. Therefore it can be welded and no problems.
  8. squirrel
    a spring is low alloy, non-heat treated steel? that's a mind blower
  9. 38Chevy454
    38Chevy454
    A sway bar is not required to be heat treated.
  10. OLDSKEWL61
    OLDSKEWL61
    weld it if it brakes redo it with something else
  11. ol fueler
    ol fueler
    Try a good industrial supply store , get a piece of 1" drill rod or cold roll . They are not that costly.
  12. REJ
    REJ
    from FLA
    Well, I tried welding it when I got home. It welded real good and when it cooled off, I started twisting it to see what would happen. It is brittle. It pulled pieces of the sway bar out with the weld, so now I have a tapered piece of 1" stock.
    I will be getting a piece of cold roll and using it.
    Thanks for all your replies, but it is not built out of normal steel, I think it was hardened on the outside by the way it pulled the pieces off.:eek:
  13. el gringo
    el gringo
    from Chicago
    Thats exactly what I expected to happen. I guess its time for me to post an intro so that people know to trust me when it comes to steel metallurgy.
    Edit: Intro added
  14. oldspeed
    oldspeed
    from Upstate NY
    If this is any help I have built a few and used 4140, heated and bent to shape then had them harden and drawn back to Rc 42-45. They have worked very well.
  15. Unkl Ian
    Unkl Ian
    Drill Rod is O1,an Oil Hardening Tool Steel.
    Also not good for welding at home.
    Mild steel is a much better choice.
    Cold rolled,or hot rolled.
  16. Unkl Ian
    Unkl Ian
    That would be my first choice for sway bars etc.
