Hey Guys, I want to do away with the vent tube on my '63 Meteor 260 v8. Can I plug it and run a pcv setup in one valve cover and a breather in the other? Has anyone ever tried it???
Kevin, If you can get a grommet to fit into your hole that holds a vent tube you may be able to just push a PCVvalve in there. If not, you can certainly plug it and run a pcv into a valve cover with a breather in the other one.
