MG Lever shocks
Discussion in 'The Hokey Ass Message Board' started by Jimmy2car, Oct 26, 2011.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    I've been told that the Armstrong/Lovejoy lever shocks used on the rear of MG's will work on early Fords. Has anyone ever done this or have any information? I don't want tube shocks on the front end of my 32 and thought this may be a good alternative.
    Thanks for any help
    Jim
  2. MikeRose
    MikeRose
    from Yuma, AZ
    A couple pics I've saved for inspiration.
    B***'s Coupe
    Kirk's modified[​IMG]
  3. wisdonm
    wisdonm
    A good source of MG shocks, they rebuild them for other retailers, and other parts is MG Limited. 414-529-3200
  4. Skeezix
    Skeezix
    from NorCal
    Apple Hydraulics may have info
    Also my Midgets were r/r at Roadstar Nelson in Sacramento Ca area.
    That was ten yrs ago and they had options then to revalve to tune them.
    They are typically replaced with tube shock conversions from Moss or victoria British
  5. 117harv
    117harv
    Some of the British shocks are aluminum and have been used in the past. I see nos ones for sale at times on the auction site.
  6. Jimmy2car
    Jimmy2car
    from No. Cal
    Mike
    Thanks so much for the pictures. That's exactly what I am looking for. I was concerned that the shock body might hit the fenders, but it appears that they'll clear.
    Now, I just have to find the model that will work. Thanks again.
    Wisdonm
    Thanks for the resource
    Anyone else with any info?
    Jim
  7. Fedcospeed
    Fedcospeed
    I run a set on the back of my tub.Apple rebuilt them and they perform perfectly,and were easy to set up.
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    Anyone have an idea of the model(s) of shocks shown in the pics? Like what were they from?
    Thanks for all the ***ist
    Jim
  9. Skeezix
    Skeezix
    from NorCal
  10. oj
    oj
    I'd be interested in where the perch's came from in the first picture. They look pretty handy.
  11. rbradber
    rbradber
    from Choctaw
    I run them on my '32 Roadster. Many mounting options.
  12. MikeRose
    MikeRose
    from Yuma, AZ
    I think B*** said his were "lovejoy" I think, and Kirk's are Armstrong. With the Armstrongs, it seems like they are all similar. The arms vary some, but I imagine you may have to modify them anyways. There are tons of them on epay. Search "Austin or MG Shocks" or "Armstrong shocks" The ones listed as Austin Healy shocks seem to be the closest to what I need. The arm is a bit shorter and seems to curve more outward instead of inward. I could be wrong though. Rod and Custom put some on a modified project they are doing. They had some cool shocks with a curved arm that they mounted going over the rearend. Not sure what those ones are from.
  13. 117harv
    117harv
    If you are refering to the perch bolts, those are 32-34 with the mech. brake actuator shaft support arm removed.
  14. need louvers ?
    need louvers ?
    They are off several different British cars of the fifties and sixties. MGBs and Midgets seem to be the easiest to find these days. I know that the most popular back in the day came off the backs of the Midgets.
  15. cederholm
    cederholm
    One of my MG buddies might have a pair from when he went to gas shocks. IM me if you want me to check for you.
    ~ Carl
  16. JJTF
    JJTF
    I've got a spare pair off my 57 MG in the garage if you need some measurements, 56-62 MGA are all the same, can't speak to the T-series or Midget. I've had excellent service from Apple Hydraulics in NY also.
  17. dana barlow
    dana barlow
    from Miami Fla.
    MGB are the best,good size twin piston,alum main case that can be painted or polished up some,if a like some shiny as I do :D:cool:
  18. KIRK!
    KIRK!
    Yep, Armstrong.
  19. PRB
    PRB
    from Az
    Triumph TR3's use the same model that will work well with any buggy spring as that's what they were designed for....you can find new or rebuilt ones on ebay. I'd go with a quality rebuild as 'new' often means China/India and the quality might not be there
  20. wisdonm
    wisdonm
    ****, owner of MG Ltd. says,
    "Will sell rebuilts,for $65 each.
    Can valve them many ways. For front or rear."
    Call 262-529-3200 for info.
  21. pasadenahotrod
    pasadenahotrod
    from Texas
    Hotrodders have been using Armstrongs since there were Armstrongs.
  22. need louvers ?
    need louvers ?
    You'll find that although they all look the same, there are a couple of different sizes. I know that the armstrongs from a MG midget are the best fitting and working for an early Ford front application. I do know that the MGB stuff is just a bit bigger. I'm not sure on the rest of the models.
  23. Brad54
    Brad54
    from Atl Ga
    I'm curious--what's the advantage to the Brit lever shocks versus American-made units, like from a '54 Buick rear?
    -Brad
  24. 26 roadster
    26 roadster
    I always used the Midget rears, (longer arms) easy to mount and rebuild, the horizontal lines seemed to flow better on open wheeled cars. Still have pair put back.
  25. KIRK!
    KIRK!
    For me it was size and performance. Meaning I didn't need a giant shock for my lightweight car. Plus, to me, they look a little more exotic.
  26. aldixie
    aldixie
    What a good idea, I have a 64 Midget under a cover in the backyard and didn't even think about them. Have a friend who parts out MG's so I am sure I'll be able to pickup a pair cheap from him.
  27. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Unfortunately my dad drags me to an import show the same day Another great show is running ,We go to the cool show first and then to the import show,Anyway Theres always 2 styles of shocks always for sale ,Big and little....Im referring to the housing ..........
  28. 26 roadster
    26 roadster
    They also have great cable wipers with the long cable
  29. Crusty Nut
    Crusty Nut
    Anyone know what happens if these are mounted upside down?
  30. You'd have a helluva time topping up the fluid, for one thing. The filler is on the side, at the top (working from memory here, it's been 20+ years since I owned an MG).
