Mickey Thompson Aluminum Third Member
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Willys, Oct 13, 2012.
  1. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Can anybody identify what this third member is for and its value? Thanks for any help.
      356 KB
      413.7 KB
      420.7 KB
      441.8 KB
      397.9 KB
      392.6 KB
    Deuces likes this.
  2. Royalshifter
    Royalshifter
    Moderator
    Magnesium for olds....$1500
  3. GregCon
    GregCon
    from Houston
    I had one of those, Mopar 8-3/4". I advertised it for $400 and sold it to the first guy who called. Then, I had several other guys offer me as much as $800 for it if I would stiff the first guy. Sorry, but no thanks!
  4. blownhemi48
    blownhemi48
    from Bergen NY
    Dave, It appears to be a Mickey Thompson Olds third member. They were used in the smaller pre 1957 Olds rears in dragsters.
  5. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Thanks for the replies, was the flange around the pinon for a dragster mount or was it for a torque tube? I have been told it was for an old Olds , I got it from a 60's front engine dragster racer/builder.
  6. Deuces
    Deuces
    I'm just curious if that bolted up to one of your trans adaptors you posted on another thread....
    I could be wrong....:eek::rolleyes:
  7. That's way cool, what's the gear ratio and is that a posi carrier? It don't look like a spool.
  8. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    No it does not bolt up to the bellhousing/ adaptors I have. Also looking for info on those, one is a Chrysler and the other is Chevrolet, look at my other postings.
  9. dreracecar
    dreracecar
    from so-cal
    Mickey made those in two sizes big Olds and little(49-50). Little centers can still be found but the internals are the hard parts, Bearings and seals are expensive, Nobody ever made a spool or posi and the only low gears came from ambulances. Mag does not age well so to try and put power to it with compond slicks on a prepped track will cause problems.
    The big flange in front was for the anti rotation plate and to put a big enough tube on the front to cover the U-joint as couplers were not made for that unit.
  10. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Can anyone tell if this is the big or small olds? I could measure if this would help. Thanks everyone.
  11. Mr48chev
    That looks like it might have more value for putting in someone's collection of rare parts then it would have for putting in a compe***ive race car. It might be one of the crowning pieces in a Cacklefest car though.
  12. Marty Strode
    Marty Strode
    We had a small - early Olds M/T center section in this dragster, I don't remember the flange being as large as the one you have pictured. These are poor pics, but they show the tube/ shield over the drive shaft, ours had a coupler. I was told M/T built some for 55-64 Chevy centers as well.
  13. Mike VV
    Mike VV
    from SoCal
    Yes, it IS the smaller , early Olds case. He/they musta done a bunch of those, as I've seen them for sale from the late 60's, to current swap meet visits.
    Mike
  14. Fecoffin
    Fecoffin
    If you pull the gears there should be a part number cast into the housing. I have an old catalog that has some of the part numbers and ***ociated years it would fit.
  15. stratostreak1
    stratostreak1
    do you still have a catalog of part numbers fot the old mickey thompson center sections? i am looking for the ones for a pontiac 9.3 center.thanks for any help
