Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. squirrel
  2. 427 sleeper
    427 sleeper
    Painting that intake is more like Blasphemy, but I like the direction you're headed with it! ;):D:cool:
    enloe, Sharpone, Deuces and 2 others like this.
  3. There is no shame in painting that intake:cool:
    enloe, Sharpone, X-cpe and 3 others like this.
  4. squirrel
    yeah, it's kind of rough...but it looks right disguised as cast iron! thanks again
    enloe, bchctybob, saltflats and 6 others like this.
  5. 427 sleeper
    427 sleeper
    Not to guy's like us there isn't. Although, some would give their left testicle for it the way it was. That's the difference between us and purist's.
    :cool:
    bchctybob, WC145, alanp561 and 3 others like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It comes off as easy as it goes on.
    enloe and Sharpone like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I can see now where the intake is cut back some right in front for mount clearance, My L79 intake was not like that....maybe mine was from a later car or something... looks good. You ain't going to fool guys that know those intakes with paint though, tough to disguise those square cornered runners!! Those Intakes do work real well.... is there a 57 Olds Pont rear axle in your future plans?
    enloe, bchctybob, Deuces and 2 others like this.
  8. That intake is oddly pitted, the purists wouldn’t want it. Painting is probably the best option to make it look right
  9. RodStRace
    RodStRace
    Total SBC newbie here, owned one for a full week now!
    Wasn't there a fairly large aluminum heat shield on some of them under the carb?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I believe that only the big blocks used those, not 100% sure though
  11. MCjim
    MCjim
    from soCal
    They were stamped steel, riveted on
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I think he is talking about the heat shield between the intake and carb, not sure though
    saltflats, Deuces, Sharpone and 2 others like this.
  13. 427 sleeper
    427 sleeper
    Wasn't that a kit that was avaliable through GM Performance?
    bchctybob and Sharpone like this.
  14. lumpy 63
    lumpy 63
    Lots of 300 hp 350s had em . But with quadrajets.
  15. squirrel
    yeah, I have one of those. They work with Holley carbs, not AFBs :p
    There were 3 different heat shields used on Chevy intakes. The steel one that was "riveted" to the bottom of the intake. The stainless steel one that fit under the carb, to contain the open exhaust crossover that heated the carb base. And the aluminum one under Holley carbs on some of the hi performance engines.
    atch, brEad, enloe and 6 others like this.
  16. squirrel
    in my dream plans, but not my current reality plans.
    brEad, enloe, bchctybob and 6 others like this.
  17. Hemi Joel
    Hemi Joel
    from Minnesota
    Squirrel, you might want to double check the calendar. I'm registered for Sick 66 as well, but in October
  18. squirrel
    yeah, it's in October....typo, my mind must have been thinking of the other thing in August with the off topic car.
  19. RodStRace
    RodStRace
    Yep, just thinking it might help camouflage the runners I quoted.
    WC145, Sharpone and Moriarity like this.
  20. squirrel
  21. snoc653
    snoc653
    from Iowa
    That heat shield looks good there. If you don’t want to modify the factory shield, you could cut one out of plate and stencil it yourself. Of course it does appear to be 3 different size fonts. Still very doable.
    Sharpone likes this.
  22. squirrel
    If I make a heat shield, it will be shaped to keep heat from the side mounted float bowls on the AFB, not the front/rear of the Holley :)
  23. Fordors
    Fordors
    Been messing with Chevy V8’s since I was 15 and I’m 75 now. Never saw a factory original engine with a heat shield on it so I googled that. BBC engines with Quadrajets on iron manifolds and an open exhaust heat crossover under the base of the carb had them, as did cars with RPO NA9
    (Evaporative emissions). Maybe those were on both Q-jet and Holley carbs, I don’t know.
    Sorry for the thread hi-jack, but I learned something today.
    Tow Truck Tom and 427 sleeper like this.
  24. squirrel
    The 350hp 396 with the Holley on an iron intake also had the open heat under the carb, and used a stainless shim heat shield under the carb.
    The small blocks in the mid-late 60s used it under the Qjet as well as the big blocks.
  25. I had a ‘69 350hp 350 that had the heat shield under the carb, i was the same size/shape as the gasket.
  26. Fordors
    Fordors
    Now that you mention it I have one of those stainless shims in my hoard.
    427 sleeper likes this.
  27. RodStRace
    RodStRace
    Jim, you had some issues with heat soak, IIRC. Make your own shield, and if you aren't running out of height, you could sneak a phenolic (sp?) spacer under it too.
    Looks stock, hides mods, adds performance!
    brEad, 41 GMC K-18 and squirrel like this.
  28. squirrel
    That's the plan...although the phenolic spacer I bought for the previous setup won't work with the new one. I do have one of those layered plate/gasket spacers I'm planning to try.
    I also blocked the heat crossover passages by using the blocked intake gaskets.
    brEad, bchctybob, saltflats and 4 others like this.
  29. MCjim
    MCjim
    from soCal
    You will run out of height real fast on a C1...ask me how I know.
  30. squirrel
    yeah, I'm aware of that.
    bchctybob and Deuces like this.
