MIG to MIG with GAS(ARGON)
Discussion in 'The Hokey Ass Message Board' started by capten icon, Apr 6, 2011.
  1. Engine man
    Engine man
    from Wisconsin
    You must have gotten a FNG to give you straight Argon to weld steel. I can't believe all of the responses saying you can use it. Most of the the MIG we do is on heavy steel with 1/16" wire and straight CO2. We were welding one night and ran out of CO2 so I used the mixed gas that we use with small wire on light steel. Kevin ran out and grabbed the straight argon we keep for aluminum thinking it was mixed. Couldn't get a decent weld with it. Very porous weld.
    I haven't heard of anyone using Argon/oxygen mix.
  2. "Darwin Awards nominees"
    Now THAT is hilarious :D:):D.
  3. gimpyshotrods
    gimpyshotrods
    Nor are you likely to. Mixing Oxygen with an inert gas for shielding would result in a weld that was oxidized all the way through. You'd be lucky if it stayed intact trough the cooling process.
  4. AG F/C
    AG F/C
    O2/ Argon kinda defeats the purpose of inert gas. The idea is to keep air(oxygen) away from the weld.
  5. Dreddybear
    Dreddybear
    I almost have no response to this :)
    Don't stick it IN your ear...:rolleyes: Is it really hard? I dunno.. I'm cracking up. I'm sorry you hurt your finger dude!
  6. jdustu
    jdustu
    from Detroit
    FWIW, You're switching from Flux Core to Mig, not "Mig to Mig with gas." Mig stands for Metal Inert Gas, same as GMAW(Gas Metal Arc Welding)....which insiuates you're already using gas.
    Not busting your chops, most people refer to them as mig machines even if they are just set up for flux core. Just throwing it out there. The more you know...lol
  7. im glad i found this thread
    i got a gas shielded mig welder for christmas i went to the local welding supply to ask about buying argon yesterday it was more expensive then i thought it would be with tank rental and all
    is the carbon dioxide/argon mix stuff cheaper then straight argon? ,
    someday id like to learn to weld aluminum but right now my shoebox needs its sheetmetal fixed
    so to weld sheetmetal and heavier with a gas shielded mig i need to get is co2/argon mix RIGHT?
  8. Both of you guys better stay away from power tools, loaded guns, fire crackers and BB guns! You two will really get ****ed up in the kitchen if you're not careful.
    Come on, really pointed the nozzle straight into his ear and pulled the trigger .lmao with that mental picture. ****s he got hurt but that's funny. Oh Yea, don't look down the garden hose, might drown.
  9. Blue One
    Blue One
    from Alberta
    I absolutely love the comments and advice you get on here when it comes to welding :rolleyes: Better than the comedy network.
    Lots of advice from guys who barely know what a welding machine looks like or how it works beyond turning it on.
    Mixed gas is what you need for MIG welding steel. 75% CO2 and 25% Argon. Period end of discussion.
    Pure Argon is for TIG welding only.
  10. Blue One
    Blue One
    from Alberta
    You're welcome, and to take it a little further make sure you have the polarity of the machine switched to wire (electrode ) positive for solid wire gas shielded welding.
    The wire you want for sheetmetal work is .023 (or .024) ER70S-6.
  11. cowboy1
    cowboy1
    from Austin TX
    I have the same welder and conversion kit. I have a argon mix of75/25 and it works great!
    Also make sure you flip the roller around depending on the wire size you're using.
  12. CRYOMAN
    CRYOMAN
    from so cal
    Not trying to be a smart *** by any means but, my supplier(airgas) sells 86%co2/14%argon as their steel mix. Mixes can vary substantially by manufacturer. I will say that I have better results with the 75-25 mix but they all seem to work. Straight argon with mig is a definite nono unless miging aluminum.
  13. satan'schariot
    satan'schariot
    that is not 100% true you use argon for aluminum mig welding.
  14. "Oh Yea, don't look down the garden hose, might drown. "
    Ahhh, this site is always good for a laugh ... after spending the afternoon raking my lawn, I needed a good chuckle, thanks much :).
  15. Blue One
    Blue One
    from Alberta
    True, gas mixes are a kind of proprietary thing everyone has their own recipe and various wild claims as to why their mix is better than all the others.
    75-25 is by far the most common and also the most effective.
    Yes you do.
  16. Not to muddy the waters here any further but lets just add some info.
    98% argon 2% o2 (oxygen) is used in mig welding, its for heavy plate with oxidation present on the materials and when spray transfer is used.
    Straight argon is also used in mig welding heavy plate that is clean when spray transfer is desired. That's very high heat, very high wire speed and most likely a water cooled gun.
    Different gas for different applications, much like wrenches .
    Staight. Co2 carbon dioxide, can be used with mig welding, however it produces lots of splatter. Most commonly its used as shielding gas with flux core wire on heavy plate . I have heard that straight co2 with light gauge material and low heat as in short circuit transfer CAN add carbon and oxygen into the weld. That promotes cracking if it happens.
    99.5% of the welding discussed on the hamb is not considered heavy. Nor spoken of in spray transfer context. But if a hamber tells as what they use at work, it very well could be.
    The Bacon frying sound is short circuit transfer and easiest for the novice or hobbiest to master. For that type of welding a mixed gas of argon and co2 is best with argon being the dominant gas. The different ratios are for different applications, and have different results and penetration characteristics.
  17. Lmao, yep just like this.
    Who died and made you Elvis?
    I suppose that if the only tool in your toolbox was a hammer it would ok to treat everything like a nail.
    Your authoritative proclamation above lacks accuracy, ( except the part about being funny)
  18. exactly viki, and well said. thought I would leave that go for ppl who knew better. didn't say it was correct, just posible as I,ve had to do it b4..
  19. Dreddybear
    Dreddybear
    You have no idea...
    2 4th of July's ago:
    :D
  20. jdustu
    jdustu
    from Detroit
    Some of you guys might get a kick out of this post I made on my blog a couple weeks ago. Of course, some of you may think I'm an idiot :D
    http://watchtheprettylight.tumblr.com/post/4174051226/theres-more-than-one-way-to-skin-a-cat
  21. bcowanwheels
    bcowanwheels
    Argon straight is for stainless and aluminum, 75-25 is for plain steel
  22. Blue One
    Blue One
    from Alberta
    Accuracy? perfectly accurate,all true :p :D
  23. 55 dude
    55 dude
    you can also use straight CO2 that is much cheaper but requires more cleanup. i use mostly a tri-mix for S.S. 304 that is food grade. really crazy expensive!
  24. Willy301
    Willy301
    As a guy who owned this very setup and added on the very add on... did you flip the wire feed wheel. The .025 wire does not work well in the .035 position. Mine had a wheel I could flip as it had both grooves in it. This will affect your wire speed and your welding.
  25. carcrazyjohn
    carcrazyjohn
    from trevose pa
    12 to 15 and you want a mix ,Argon and co2
  26. bonez
    bonez
    from Slow lane
