mig troubleshooting ?s
Discussion in 'The Hokey Ass Message Board' started by dzahm, Jul 21, 2008.
  1. dzahm
    dzahm
    from NC
    I am a novice welder- using a friends hobart 140 (110v) solid wire with gas. No formal teaching, but taught by a bodyman to do mainly sheetmetal work. I have done well but as I try bigger projects (NO SUSPENSION or frame work before that gets started) I have run into kinda an odd occurance- 2 actually maybe related or not. 1. sometimes welding I get a pulsing into the puddle- turning up the feed sometimes helps but not always- welds are not pretty when this happens but are strong with good penetration- can someone explain what is happening? 2. This is a weird one- I have recently had the arc begin to occur ABOVE the puddle- it also changes in sound- not like bacon frying but more of a hissing (or fizzing) sound. THis seems to occur after welding a while, and improves if I wait a few minutes before restarting. It doesn't seem to change if I change ground location, voltage, or wire speed . I put a new tip on and cleaned the end- it still comes/goes. Naturally this doesn't happen when my experienced friends are in the garage- anyone know a cause for this?
  2. PsychoBandito
    PsychoBandito
    from Montreal
    The fizzing means you have entered spray transfer as opposed to short circuit or globular, which is high heat and low wire, which would explain why after a lot of welding the piece becomes very hot. The pulsing can be to much or not enough wire.
  3. slamdpup
    slamdpup
    i was gonna say to much wire not enough heat..but im no pro at all..
  4. adamabomb76
    adamabomb76
    from York, Pa
    I'll just add that new metal is differant than old. Lots of impurities that make for alot of pop, smack, and fizz.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Besides the above suggestions, check to make sure your ground is making good contact and also change the location you attach it.
  6. John_Kelly
    John_Kelly
    Also run some wire out and watch to see if it is feeding steadily. CAUTION! Don't let it contact anything that is grounded! You may need a new liner, or your pinch rolls that push the wire out could be loose.
    John www.ghiaspecialties.com
  7. Bobert
    Bobert
  8. rev106
    rev106
    Clean surfaces. Impurities in the metal. Also make sure your tip is clean, that makes a huge difference. Also you could be maxing out your duty cycle on the welder after a while, so as you go along it will not work as well. Otherwise, I think all the bases have been covered in the above replies.
  9. Mudslinger
    Mudslinger
    I have that same welder. Make sur ethe tension setting on the wire feed is enough and the wire feed is up enough.
    I get problems when I drop the wire feed down it starts spitting. If I remember correctly without checking around the 30 or so mark on the feed control it starts sounding like bacon sizzling and thats what ya want.
  10. blown41
    blown41
    Here's a quick way I check my liner and drive rollers. Hold the gun about an inch or so above the floor and feed the wire straight into the concrete. If your liner and drive rollers are good and tension is correct, the drive should keep pushing and make a birds nest on the floor.
  11. rc.grimes
    rc.grimes
    from Edmond, OK
    A lower quality wire will often hiss. The small hobarts like a bit more feed than normal after they have alot of use on the liner. If the tip heat sokes it will add quite a bit of drag to the wire as well so be very concious of your duty cycle. That is the reason your problems went away after a break.
  12. man-a-fre
    man-a-fre
    Mabe you met your duty cycle and the amps are dropping off .
  13. 392_hemi
    392_hemi
    Sounds like you have too much stick out. Contamination, inadequate wire speed or gas supply could also be issues.
