Mig welding in Tight places!!
Discussion in 'The Hokey Ass Message Board' started by rustypipes, Mar 17, 2010.
  1. rustypipes
    rustypipes
    from san jose
    I been encountering few instance where Im trying to weld in tight confined spaces where I cant fit in with my welding mask on to see what Im welding, But when take the helmet off Im able to get in and see but cant weld cuz no eye protection.
    Was thinking about just rigging up some goggles with darker shade lens and wearing a beenie but really dont want to burn my face off with limited protection!! I was wondering what you guys do or if there is and equipment out there that allows your melon to get in to small spaces.
    Thanks
  2. GREASEMONKEY72
    GREASEMONKEY72
    i usually end up being uncomfortable or welding blind
    i would think you could make some kind of mask with a face shield thatll let you get in tight spots, just never tried to make one myself
  3. modelacitizen
    modelacitizen
    they make little hand held masks for situations like that.. I can't remember where i got mine but it's indespensable
  4. R Frederick
    R Frederick
    from illinois
    I like it when my sensor panel gets blocked by something so my shield won't turn dark when I strike an arc.
  5. junk yard kid
    junk yard kid
  6. Fordguy321
    Fordguy321
    from Arizona
    LOL yeh i hate!
  7. Pat Pryor
    Pat Pryor
    yep
  8. MEDDLER1
    MEDDLER1
    What about a nomex ski mask?I bet with one of those and some good goggles it would work.Nomex is a flame resistant material,alot of refineries require the workers to wear it hell I bet you could even get one from fastenal or grainger or look into racing safetywear.Hope this helps!
  9. freakboy
    freakboy
    I just love when that happens! especialy how close i get to the weld just to be able to see what im doing.
  10. onlychevrolets
    onlychevrolets
    Almost all my welds are hard to get at , I've learned over the years how to weld without seeing what I'm doing, then I check it out with a mirrow. Most of my stuff is over head and on top of something like a 3 inch pipe.
  11. AntiBling
    AntiBling
    Some guys make actual leather hoods for just that occasion. I haven't made one yet but I should before I have the need for one.
    Or you could walk the cup and weld blind if you know what you're doing.
  12. brad2v
    brad2v
    I can tell you that welding barefaced will give something akin to hell of a sunburn!
  13. onlychevrolets
    onlychevrolets
    yes Brad it will and over time skin cancer...
  14. brucer
    brucer
    from western ky
    what kind of welding helmet you got?
    i had a jackson, then switched to a hobart, and i finally scored a topend Speedgl*** helmet cheap. the speedgl*** helmet is alot more compact and lighter than the others i had..
    there are also different size guns you can use..
    other than that its just welding standing on your head ,running a bead lefthanded with your arm fully extended looking through one eye...
  15. barslazyr
    barslazyr
    I took a pair of goggles for the cutting torch and changed out the lens for a 10 shade and it worked great.
  16. Captain Freedom
    Captain Freedom
    from Upstate SC
    It works for the chinese
  17. Nelsen Motorsports
    Nelsen Motorsports
    Now thats funny right there.
  18. They actually have Nomex welding hoods or Pyrovatex is another flame resistant material. You can get welding hoods made of either from most welding supply places.
    Where I work, someone made a hood out of leather and put an auto-darkening lens in it... The lens is just held in place by wire. It works great for welding in tight spaces.
  19. choppedsled
    choppedsled
    from Spokane WA
  20. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I seen guys just close there eyes , I dont know if cutting gl***es come in different tint
  21. mikeyfrombc
    mikeyfrombc
  22. curt56
    curt56
    You can buy a soft hood at any welding supply. If you need it more then once its worth the money
  23. Rich B.
    Rich B.
    from Portage,IN
    Burning goggles w/dark #10 lens, welders cap, and bandana
    over your face.
  24. tiredford
    tiredford
    from Mo.
    I put on sunblock and close my eyes.
  25. Lazer5000
    Lazer5000
    Just use bolts!
  26. Belchfire8
    Belchfire8
    It's hillbilly as hell but I have taken a piece of cardboard and cut out a hole big enough to tape a lense over. Large enough to cover my face small enough to fit in a small place. Only problem is that you have to use one hand to hold it, but if it's that tight of a spot you can't use two hands in there anyway. I suppose you could rubber band it around your head, but even I am not that hillbilly....:rolleyes::D
  27. williebill
    williebill
    Good ideas..Thanks to all..been a while since I checked out the welding supply store,sounds like I need a new leather helmet
  28. Hal_396
    Hal_396
    I've used a sandblasting hood before with the changable lens. Removed the clear and put in a dark lens. Didn't have much welding to do so it worked out great. Sounds like a leather hood would be the better way to go.
