MII shock angle questions
Discussion in 'The Hokey Ass Message Board' started by Fat_46, May 25, 2005.
  1. Fat_46
    Fat_46
    All - I'm finishing up the airbag setup on my MII front. I added a bumpstop and am adding shocks as a secondary safety feature. Is there a range for the angles the shock can have? Its mounted behind the a-arms, and seems to look best at about a 15 degree from vertical mount...but i haven't welded the mounts in place yet...
    Thanks in advance
  2. cleatus
    cleatus
    from Sacramento
    Ideally, it should be pretty close to the same sweep that the suspension travels through.
    Otherwise it'll have a side load on the shaft & seals and wont last as long.
  3. 38Chevy454
    38Chevy454
    In general a shock is most effective directly in line with the travel, so just make it as close to the arc of the lower A-arm as you can. 15 degrees off the line of travel is fine.
