Hot Rods Mill Slag Removal ?
Discussion in 'The Hokey Ass Message Board' started by swade41, Jun 28, 2016.
  1. swade41
    swade41
    from Buffalo,NY
    I believe that's what the dark gray/black stuff is on raw steel. I thought I remembered a thread on here about an easy way to remove it but my search couldn't find it. What do you guys do ?
    I dressed the welds with a flap disc when I welded the caps on but thought this might might not be good for the round surface of the tube staying round if done down the length. I want to either paint or powder coat this bumper as a final finish since chrome prices were crazy.
  2. Happydaze
    Happydaze
    Grit blasting.
  3. BradinNC
    BradinNC
    Fastest way would be chuck it in a lathe and use crocus cloth, finish with 400 grit/scotchbrite.
  4. hotroddon
    hotroddon
    If you are going to powder coat it, they will sand blast it first.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
  6. That isn't mill slag that is from the oil in process when the tube is drawn. You get mill slag on hot rolled steel.
    That said I would spin it and take a piece of emery cloth to it.
  7. swade41
    swade41
    from Buffalo,NY
    I was thinking I read something about electrolysis removal, but if the powder coater is going to blast it anyways. I just don't want a blasted textured surface as the final finish.
  8. Let the powder coater deal with it.
  9. DDDenny
    The lathe part is right, but crocus cloth will hardly polish T. G. and P. let alone that scale.
    That stuff even requires a pretty agressive emery too, I know, I had to clean that **** up for thirty years whenever a "fabricator" cut a piece of it saying "it's just mild steel".
  10. 48stude
    48stude
    I use Rust Cure to remove mill scale . It contains phosphoric acid . I found this by accident when I left a part I had sprayed with Rust cure on a piece of hot roll 16 gage . When I picked up the part , the metal beneath was shiny metal. I used it to strip both side of a 4'x 8' sheet of 16 gage. You have to let it sit on there for a while ,but it will dissolve it. Bill
  11. Johnboy34
    Johnboy34
    from Seattle,Wa
    I don't think powder coaters like tubes that are totally sealed also?
