Millermatic 250 wire feed issues
Discussion in 'The Antiquated' started by Roothawg, Jan 24, 2026.
  1. Roothawg
    Roothawg
    Hey guys, just trying to troubleshoot my 30 year old MIG welder. Recently, it started getting difficult to weld with and I noticed that the wire wasnt feeding consistently. I am a ****py welder, so I need all of the equipment to do it's part.
    I replaced the drive spool wheels and liner and it still seems to be slipping. I have ordered a new drive spool tension spring to see if mine is possible losing it's tension.
    It's a 1995ish Millermatic 250.
    Any ideas?
  2. jimmy six
    jimmy six
    Correct wire size for the driver rollers.
  3. Roothawg
    Roothawg
    Checked that first. In my old age, I wondered
  4. jimmy six
    jimmy six
    When u pull the trigger do they spin and try to drive the wire?
  5. Roothawg
    Roothawg
    I'll have to take a look. I believe it starts then stops....just going from memory.
    jimmy six likes this.
  6. Nacifan
    Nacifan
    Please check your gun liner
    They don't last forever and beleave it or not ca get some "copper gunk" built up in side. I went to a Tweco Gun in 1980 and have never had a "gun liner issue"
    jimmy six and Roothawg like this.
  7. Roothawg
    Roothawg
    I put a new gun in it about a year ago. It’s a generic Amazon job.
  8. deathrowdave
    deathrowdave
    from NKy
    Does your welder have 3 switches upper left corner when you open door ? My 250 does and you maybe set to spot weld
    Roothawg likes this.
  9. Roothawg
    Roothawg
    Dunno. I don’t think so. I’ve owned it for 30 years and don’t remember seeing that. I’ll look though.
    I’m sure it’s lack of maintenance. I’ll spend some time chafing all the consumables etc adjust the tension, once I get new drive wheels and spring. We will see if that makes any change.
  10. lostn51
    lostn51
    from Tennessee
    Once you get it to behave properly take a piece of cloth fold it around the wire before it goes into the gun and put a clothes pin on it. This will clean the copper dust or whatever grime off and will keep it from slowing down and becoming erratic. Also if you’re not careful you will actually weld the wire inside the liner and then you have to replace it. Depending on the welder you might have to replace the entire thing like my little Lincoln 110.
    I’ve done this for years and never had any problems with the liners.
  11. deathrowdave
    deathrowdave
    from NKy
    I use scotch bright and one of spring type paper clips for this chore .
  12. 37 caddy
    37 caddy
    from PEI Canada
    Check how tight the wire roll is,if the big plastic nut is too tight it makes it hard to spin.also the tension on the wire roller maybe wind it down a turn or two.The problem is likely there if it is not "birdnesting",thats when the wire all backs up in the machine. I also take the rollers out and spray them with cleaner and wipe them off,that helps some too.
  13. Roothawg
    Roothawg
    So basically what it does is you are welding along, s as md the wire just stops coming out. No bird nesting. It makes it very hard to get a consistent weld. Lord knows, I need all the help I can get.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    sounds like a bad liner to me..... maybe you need to weld with the door open and have someone watch the drive rolls while you weld to see if the drive motor stops. We ran those welders at work and they were used 16 hrs a day and I had to replace many liners and drive wheels, a few circuit boards and I think one drive motor...
    Bill's Auto Works likes this.
  15. deathrowdave
    deathrowdave
    from NKy
    They are tough as a nail
  16. Roothawg
    Roothawg
    I changed the drive wheels (again) and watched a video about adjusting the spring tension. I welded all day with very little issues. I went ahead and ordered a replacement spring today. TRhe ones I had ordered were the wrong ones so.....
    down-the-road likes this.
  17. Bentrodder
    Bentrodder
    from Cotati
    Also check the br*** guides going into the drive roll mechanism. They get gummed up with dust and oils thats on the wire. I clean them with small number drills in a pin vice. They can get packed up tight.
  18. Roothawg
    Roothawg
    Thanks. I’ll make sure I take a look at that.
    Bentrodder likes this.
