Technical Milwaukee charger warning
Discussion in 'The Hokey Ass Message Board' started by HOTRODNORSKIE, Apr 4, 2024.
  1. 05snopro440
    05snopro440
    We get it. You don't care about taking risks regardless how much evidence there is to the contrary. Seatbelts and unplugging things not in use aren't some crazy idea that you act like they are.
  2. 05snopro440
    05snopro440
    I'll ***ume you meant anecdotal. I can tell you that accounts of battery chargers causing significant house fires are not myth. It's likely not a huge percentage of them, but when they're in millions of homes, any amount of caution in their use can help a significant number of people.
    My electrical fire investigator colleague is well versed in these types of fires, especially for power tools and boost packs. That's not mythical or for no reason. Residential fires occur in a small percentage of residences, so it's not surprising that power tool charger fires wouldn't occur to a significant number of chargers. However it's surprising from this thread how many people didn't realize the potential risks. Caution here doesn't cost money.
    I hate to spoil it for you, but appliances with metal enclosures can still cause fires.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    I still eat steaks & burgers & bacon as well . With all that anxiety , how do you manage to live ?
    o_O:confused:
    GlassThamesDoug likes this.
  4. continentaljohn
    continentaljohn
    At work we would have a dozen or more chargers going when we left at night. This is so we all have good charged batteries in the morning. We warned management but felt it was safeo_O.
    As a former electrician I put a disconnect switchs on certain outlets banks such as charger’s and machinery in my shop . A simple toggle switch next to the light switch would be sufficient. The lights go off and so does any questionable items. I’m human and have wondered did I turn off that bench grinder, sander, plasma or welder a simple disconnect would do it all.
    TrailerTrashToo and G-son like this.
  5. 05snopro440
    05snopro440
    There was a shop fire at a local dealership overnight. It was caused by a power strip built into a toolbox that shorted out. Luckily the building was saved but there was a ton of damage.
    You're right, a simple disconnect does a lot to decrease risk.
  6. I've probably seen almost as many failures as your fire investigator friend during my career as an electrician. Not all of them develop into something that causes significant damage, some just leave a smoky mark and the fire department wasn't called. Two things bear mentioning...
    One, be aware of your receptacles. There are four grades available, with durability being the difference. There's 'consumer' grade, typically found in the 'hardware' aisle in grocery stores and only rated for 15 amps. Avoid these. Then there's 'residential' grade, generally installed when a home is built, most are 15 amp. A small step up, but constant unplugging/plugging will wear these out and can be a cause of fires. Next up is 'commercial' grade, much more heavy-duty and designed for heavier use. Personally, I won't use anything lighter at home, and always replaced failed outlets with these. Available in both 15 and 20 amps. You can install a 20 amp outlet on a 15 amp circuit as long as it's protected with a 15 amp fuse or breaker. Last, there's 'Hospital' grade. Designed for heavy use, if you're plugging/unplugging devices a lot and want ultimate reliability. Each step will roughly double the price, with hospital grade costing $7-10 each. I also prefer nylon bodies over hard plastic, the nylon won't break like the plastic ones can. I don't like power strips, they're fine for small loads like computers but not so good for heavier loads. And I've seen more than a few that lack the UL listing, always imports. I'll note that these can put out a lot of smoke when they fail...
    Two, circuit breakers. If you're using these as your daily disconnecting means, I would recommend getting 'switch rated' breakers. Standard breakers are not designed for switch use and can fail if used for that. These aren't available for all panels, keep that in mind. Better yet, get 'arc fault' breakers, they are designed for this very scenario and you won't need to turn them off. And if you have a Federal Pacific or worse yet, a Zinsco panel, give serious thought to replacing it. Both are long out of business because of fire issues, particularly the Zinsco.
  7. SuperKONR
    SuperKONR
    from Earth
    Glad this was brought up, I hadn't thought anything of my tool batteries. I use my cordless stuff a lot and just bought another battery the other day.
    05snopro440 and lothiandon1940 like this.
  8. bobss396
    bobss396
    I charge batteries outside my garage, also the car if it needs some help.
  9. harpo1313
    harpo1313
    from wareham,ma
    I have a cheap timer that I plug my charger in and set for an hour a day. works well for me,
    TrailerTrashToo and 05snopro440 like this.
  10. error404
    error404
    from CA
    I've thought about putting an easy-to-get-at master switch for the entire garage, when I dream of actually having a shop. Nothing I would have in there needs to have power when I'm not in there. My tiny 1 car garage is basically a storage unit for tools and parts, and I do all my work outside.
    G-son, Budget36 and lothiandon1940 like this.
