Hot Rods Mis-named Automotive Equipment...
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Jun 13, 2021.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ever see a Fast Back p*** the front end?
  2. I remember when it was regular and unleaded, now it’s regular unleaded!
    millersgarage, fauj and Truck64 like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Propeller shaft or prop shaft changed to drive shaft, cars never had a propeller, if it did it would be an amphibian. JW
    fauj, VANDENPLAS and loudbang like this.
  4. X38
    X38
    But it does propel the vehicle;)
    Ned Ludd, jimmy six and VANDENPLAS like this.
  5. lothiandon1940
    lothiandon1940
    ............and remarkably, he survived.:eek:
    hotrodjack33 and fauj like this.
  6. RidgeRunner
    RidgeRunner
    from Western MA
    Very early submarines were small enough to be carried on ships, thus the traditional "boat" reference still used today.
    Ed
  7. RidgeRunner
    RidgeRunner
    from Western MA
    For well over 60 years it has really -issed me when some self anointed "expert" has described a "scavenging air blower" (GM's term) as ****ing the exhaust out of the engine. They push/pressurize the air on the diesels they were built for and as later adapted to hot rod engines.
    Ed
    Truckdoctor Andy and VANDENPLAS like this.
  8. Crafty
    Crafty
    from UK
    Reading threads on here, I learnt a new US term, what you call a drive clamp we call a jubilee clip. Having looked further it seems jubilee is the name of the company https://www.jubileeclips.co.uk/about-us/
    VANDENPLAS likes this.
  9. seabeecmc
    seabeecmc
    Arrow lights. Ron
  10. Mark Grabo
    Mark Grabo
    from Upstate NY
    motor mount is really an Engine Mount . Motor = electric
    egads, deathrowdave and VANDENPLAS like this.
  11. winduptoy
    winduptoy
    no service brakes, that would be, to differentiate from emergency brakes and even driveline brake ...unless you are from the school of no school where you spell it breaks....driveline breaks.
    57Custom300 likes this.
  12. Happydaze
    Happydaze
    Or even Little Ends, naturally living opposite the Big Ends aka (Connecting) Rod Bearings.
    Chris
  13. onetrickpony
    onetrickpony
    from Texas
    Around here, a Welsh plug is mostly flat just slightly concave. The other style is a cup plug.
    egads and Guy Patterson like this.
  14. MeanGene427
    MeanGene427
    from Napa
    When I first moved to Kaleeforneea from NY, I was tasked with fixing some piece of construction equipment, and I said that a stick of Redi-Rod would work- they looked at me like like I spoke Swahili. Well, that was the common (and a brand) name for all-thread rod back East
  15. 51504bat
    51504bat
  16. woodiewagon46
    woodiewagon46
    from New York
    "Frame off" restoration vs "body off" restoration. If you do a total restoration of a vehicle, you remove the body from the frame, you don't take the frame off the body. The only way to do that is to roll the car onto it's roof and then lift the frame off the body. "Body off" restoration is the correct terminology.
    Ned Ludd and Fortunateson like this.
  17. Truck64
    Truck64
    from Ioway
    When I was stationed "over there", all the cars still had a smaller bulb, like what would be found in a 2 cell flashlight, below the headlight, er headlamps. Very low current draw so they wouldn't draw down the battery. These were called parking lamps. I think that's how the phrase started. When asked I was told it was common before streetlights became widespread, that when parked in towns people would turn these on when parked on streets.
    Ford Motor Co.
    American Motors
    General Motors
    Nissan Motor co
    Bavarian Motor Works
    Department of Motor Vehicles
    Yeah ... good luck changing that fellas.
  18. pirate
    pirate
    from Alabama
    Standard Transmission = Stick Shift
    Automatic Transmission = Slush Box
  19. Adjustable wrench
    Crescent wrench
    Thumb screw
    upright
    Spindle
    Knuckle
    Vertical link
    side gl***
    Door gl***
    Side light
    not even sure what you would call it but the plastic surround on door handles and license plates in newer cars have searched and searched in parts depart computers ........ it’s called a Plinth !! Wth !!
    Truckdoctor Andy likes this.
  20. 51504bat
    51504bat
    And I guess we don't want to bring up the issue of dikes?
    Flathead Dave, fauj and Truck64 like this.
  21. dwollam
    dwollam
    Model T's had parking brakes on the rear wheels. Foot brake was a band in the transmission. The early ones were cast iron with NO linings. They were for parking only. Later ones got linings because after the axle seals started (continued) leaking the metal to metal shoes did nothing.
    Brake shoes vs pads. Youngsters call brake shoes pads probably because they have only know disc brakes. Drum brakes use shoes, disc brakes have pads kids!
    Dave
  22. 1time
    1time
    from minnesota
    Tappits vs rockers
  23. Guy Patterson
    Guy Patterson
    On the ship vs. boat , a ship is 172 feet and longer a boat is less than said 172 feet. this is per US Navy
    fauj likes this.
  24. No problem with that conundrum. A rim is one component along with a center or spokes and a hub, when properly ***embled comprises a wheel. My worst pet peeve but I labor in vain. Wheels ain't rims, kids and they sure as Hell ain't rimz
  25. Semaphore trafficator fluid just doesn't have the same ring to it!
  26. DDDenny
    I always get a laugh when I hear "frame off" restoration and it's a unibody car.:confused:
    jimmy six likes this.
  27. jimmy six
    jimmy six
    Unless it’s a single jack..
  28. jimmy six
    jimmy six
    They were fenders once when you could unbolt them. Our 40’chevrolet has rear fenders and are 56 Ford has quarters..
  29. HOTRODPRIMER
    HOTRODPRIMER
    Who dreamed up the name Easy outs, nothing easy about it. HRP
  30. Jokester
    Jokester
