Hot Rods misfire on an olds 403
Discussion in 'The Hokey Ass Message Board' started by chunk40, May 4, 2016.
  1. chunk40
    chunk40
    been a minute since I have had a chance to log on.....ok my 403 blew a head gasket i replaced them both and now she is running but,I have a missfire that I can't figure out.....new plugs,wires,distrubator and an older coil....had an extra thinking thats the problem.........timing is right just can't figure out what is going on......when im driving and jump on it it tries to clear up but doesnt......it's got to be something simple.....any advice??????? thanks ken
  2. oldsjoe
    oldsjoe
    Double check firing order. Or did a valve get damaged when the head gasket went south? Try filling the cylinders with compressed air, listen for air leaking out either at the carb or exhaust in each cylinder. I do this test with a compression gauge adapter with the Schrader valve removed. Or it could be as simple as a bad wire, or carbon or other junk on the freshly installed plugs. Let us know what you find it's always good to hear the problem and the fix! Joe
    stimpy likes this.
  3. chunk40
    chunk40
    thanks for the info
  4. stimpy
    stimpy
    sounds like wires #5-#7 are crossed .. at low loads not noticable but out on the road it feels like its loading up . also check for a plug wire that might be laying on metal and shorting out ( W Hei you have to use good wires cheap sets do not cut it . , just because its new doesn't mean its working right , fixed a O/T that just had new wires put on by someone lazy ( they make wire hangers and route them for a reason and not zip tie them together ) and the #1 plug wire was laying on the manifold and burned thru and was misfiring ocasionally when the wire layed near the manifold and always when it rained and also was getting crossfire where they were zip tied together ( cheap , cheap autozone wires )
  5. oldolds
    oldolds
    Vacuum leak?
  6. Missing at idle, under power or both? Try running the engine at night, the darker the better, and have a look if you can see any blue glow around anything in the high tension side of your ignition.
  7. chunk40
    chunk40
    Thanks for all the input......had to walk away for a few days gonna get back on it tomorrow......got to get her ready for the rust revival
  8. chunk40
    chunk40
    ok....when i pulled the heads i never took the lifters loose could this be the problem.....wires are correct....no flashes when running in the dark....everything under the cap is new.....i am stumped
  9. oldsjoe
    oldsjoe
    I'm not understanding that you didn't take the lifters loose? Are you saying you didn't remove the rocker bolts? I'm still thinking there is either a burnt or damaged valve from the blown head gasket. Joe
  10. chunk40
    chunk40
    i lifted the heads straight up when i slid them back in place my wife slid the push rods back in and i bolted it down.....the valves looked good but ya never know
  11. chunk40
    chunk40
    been looking around and found some posts about mixed up push rods....think that happened they are for the proper side just not in the orginal place......kinda got mixed up......
  12. oldsjoe
    oldsjoe
    There really is no valve adjustment on that engine. You just torque the Rocker Arm Pivot Bolts to 25 FT.LBS. I believe is the spec. You might want to check my memory on that. Does the car spit through the carburetor at all? Joe
  13. chunk40
    chunk40
    Just threw the exhaust......i did have 2 valves that were nice and white
  14. chunk40
    chunk40
    Is there a certain order to retorqueing the nuts
  15. 26Troadster
    26Troadster
    i'm thinking something with a valve. if you had 5 & 7 crossed (which some olds sm blocks have the firing order wrong on the intake) then you would have had to move the dizzy to make run. go with the compressed air trick as it will tell you if you have a valve problem. one thing i like about olds is you can remove the head with out removing the intake, just unbolt the side your working on.
  16. 26Troadster
    26Troadster
    yes there is but i would have to look in a book to get it right head to block but the rockers should be in sets of two and just run them even. if this is a motor that was gotten from somewhere else, someone may have shortened the shank that goes through the rocker to stop a lifter from tapping and it may now be in the wrong spot causing the valve to hang open.
  17. chunk40
    chunk40
    Sweet will mess with it a little tonight
  18. oldsjoe
    oldsjoe
    The problem sure sounds like a valve to me also. Joe
  19. chunk40
    chunk40
  20. chunk40
    chunk40
    Well did the dollar bill trick on the exhaust and it p***ed.........oulled plugs while running and all cylinders reacted......so its got to be a gremlin
  21. oldsjoe
    oldsjoe
    That's great news. Maybe try checking the wires very close to see if you have a bad one. What type distributor are you running? Joe
  22. chunk40
    chunk40
    Brand new gm hei.....gonna drag it to rust revival as long as the rv checks out
