Technical Misfire Woes
Discussion in 'The Hokey Ass Message Board' started by BowtieGoofy, Jun 4, 2019.
  1. BowtieGoofy
    BowtieGoofy
    Hello everyone. I have a misfire that started last week, and I cannot seem to determine what is causing it. I have no real loss of power, my engine does not overheat at all, and I’m not burning oil.
    I changed out my intake manifold two weeks ago and found on Saturday that three of the bolts were pulling. I tightened them down. I also found that plug 2 had white buildup on the node and tang. The misfire seemed to get worse after I cleaned it, go figure.
    I thought it may have been a blown head gasket, but the block test came back negative. I feel the miss most when the motor is warmed up and when I accelerate. The fuel air mix was rich before Saturday and I have since leaned that out. I’ve not done a compression test yet. Any ideas?!
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Fresh plug instead of cleaning #2 plug would be a starting point.
  3. 6sally6
    6sally6
    Wires are pretty cheap if you're interested in just swapping parts!
    Good starting place is.......get the engine good and warm. Then take a spray bottle and squirt a stream of water on each primary header pipe (or mani) and note which one does NOT SIZZLE. That's you missing cylinder. Now you have a starting place.
    6sally6
  4. BowtieGoofy
    BowtieGoofy
    Is it possible something is wrong inside the plug after only 2 months? I didn’t see any cracks when I checked everything. I traced all the wires and taped every spot I found even the smallest crack.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I think you covered the problem with tape.
  6. BowtieGoofy
    BowtieGoofy
    I was trying to prevent arcing to the block. I know, replace is better, but I was on a roll and in the moment.
  7. sunbeam
    sunbeam
    Mist the wires with water and check it at night bad wires will light up like a Christmas tree..
    WB69 and 31Vicky with a hemi like this.
  8. mark latham
    mark latham
    I agree with what others are saying about starting with new wires but did you happen to drop a plug while cleaning it or side load it with a socket? A crack won't always show in the plug. When I was younger I dropped a plug while setting the gap and my Dad said remember what cylinder you put that plug in because if you have a miss it's going to be that plug. Sure enough, even though the plug looked fine it had a miss. Changed just that plug and it was fine.
    Truck64 likes this.
  9. BowtieGoofy
    BowtieGoofy
    The more I think about it, the more I’m inclined to replace that plug. I didn’t drop it, but you never know. I have to tighten mine with a combo wrench because I have no room, so that may have done it.
  10. big duece
    big duece
    from kansas
    Even over tightening at a tight angle with a spark plug socket can crack the porcelain... you can check resistance of plug wires with ohm meter. Fought a misfire under load in OT work van pulling trailer, wires cured it.
  11. BowtieGoofy
    BowtieGoofy
    So, replacing the plug did not work. Boo. I’m going to have a leak down test run on the problem cylinder next week to see if we can’t pinpoint the issue.
  12. Start with the obvious stuff!!!!
    For example plug wires With small cracks that need tape. SOB if you can see a crack in the insulation it’s done.
    Eye eye eye
  13. whateverit takes
    whateverit takes
    from Florida
    I found a misfire on my truck after swapping out plugs, wires and distributor cap by running her in the dark. Turns out I cracked two plugs during the install. I sprayed water on the hot header tubes of the offending cylinders to isolate the miss. Pulled her into the garage and turned out the lights. I was able to see the arcing spark.
    Ernesto
    Truck64 and 31Vicky with a hemi like this.
  14. BowtieGoofy
    BowtieGoofy
    I know I’m going to have to. This car is a daily driver and I need it to run well. The buildup on cylinder 2 still bothers me though. I am interested to see why that is happening.
  15. Mr48chev
    I'd say you damn well answered your own questions. Quit being cheap and buy a new set of wires and a new set of plugs.
    Tri-power37 likes this.
  16. 4dFord/SC
    4dFord/SC
    I agree. Just went through a similar scenario on my flathead, and it turned out to be plug wires. An easy way to check is to start the engine in a dark garage and look at the plugs and wires. If you see arcing, especially between the plug base and the cylinder head, the wires should be replaced.
    Tri-power37 and Truck64 like this.
  17. BowtieGoofy
    BowtieGoofy
    It’s amazing when you don’t know something. An older mechanic friend of mine told me the “why” behind some off what I am hearing hear and it’s clicking. If the #2 cylinder wire is bad, not o it does that contribute, but it’s also burning my coil out. Doesn’t help that the coil is older. It feels good to have some understanding and not freak out about a major problem inside of the motor. I know that’s still possible, but knowing this other information makes t easier to believe the problem is not as bad as I thought.
  18. King ford
    King ford
    from 08302
    Bad wire equals weak spark which equals fouled plug....the knee bone is connected to the leg bone!!!
  19. Truck64
    Truck64
    from Ioway
    The coolest "new" tool I have is a Heathkit ignition oscilloscope. I had a real problem with arcing at coil and distributor cap in high humidity and replacing parts with new just made it worse. Just because parts are new or NOS doesn't mean they are any good. I've heard that tale about dropped spark plugs before, and it's true. It's rare, though sometimes a plug is defective right out of the box. Mistakes happen.
    The 'scope lets you look at each cylinder firing voltage trace individually, both primary ignition and secondary (high tension) and, altogether as a whole. An ignition coil will only supply as much voltage as required to fire the plug and no more, when parts or tolerances are defective than the voltage can start to spike very high. The scope will show this, high resistance in the wiring, defective condenser, worn distributor bushings etc.
  20. BowtieGoofy
    BowtieGoofy
    Did a compression test this weekend. All cylinders were within 2lbs of each other, so that’s a relief. In fact, I got a consistent 122 on all but 2 cylinders. No cylinder leaks! Everything points at the wires(like you all said), so a new set goes on this weekend after I get paid. Ha!
  21. BowtieGoofy
    BowtieGoofy
  22. BowtieGoofy
    BowtieGoofy
    Ok, I bought the wire set listed above and installed them. On the distributor, the boots are 90 degrees instead of the stock style straight boots. I wonder if this is making the connection there difficult as the wire has to bend to get into the distributor cap. I drive the car and it still has a miss, actually t feels like more than one now.
  23. Truck64
    Truck64
    from Ioway
    Have you ran it at night or in dark garage to check for arcing? High voltage is weird stuff. If it's arcing to ground somewhere, or inside the cap or at the coil, etc., and you replace parts, it may well get worse, till the actual cause is remedied.
  24. BowtieGoofy
    BowtieGoofy
    No, not yet. Guess that’s what I’m doing tonight. I can’t imagine what it would be now that I have good wires with no cracks. The distributor was new. Only thing that has real “miles” on it is the coil. Maybe that’s it.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What's this new distributor you've installed and why were intake bolts loose? Did it run OK before you tore into this thing? What engine exactly by the way?
  26. Tri-power37
    Tri-power37
    Buy a new cap, rotor, wires and plugs. Why? Because they are cheap and easy to install! Make sure you feel and hear a nice little click when you push the wires on the cap and spark plugs - putting a little dielectric grease inside the boots helps them slide on and helps conductivity. Take your time route the wires nicely.
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    On those 90 degree terminals, slide the boot back a little, and make sure the terminal goes all the way in. Then push the boot into place.
  28. 26 T Ford RPU
    26 T Ford RPU
    Since you have replaced all the plugs this won't help now but may others.....i don;t know how you cleaned that plug but NEVER use a wire brush as this leaves a metallic coating on the insulator and can't really be fixed short of replacing the plug/plugs. JW
  29. BowtieGoofy
    BowtieGoofy
    Just changed the wire ends back to the stock style straight connectors at the distributor. I then ran it in the dark to heck for arcing. Nothing. And it is still running rough. Ugh.
