Technical Mismatched EAB Heads?
Discussion in 'Traditional Hot Rods' started by Darin Younce, Jan 5, 2022.
  1. Darin Younce
    Darin Younce
    Bought these from a well known source and am wondering am I being a bit OCD concerning them not being a match set? BTW , the sorta grainy look is dew settled on them after I set them under a shed overnight , they are
  2. They look like a matched set to me, not sure what your hang ups are. All of the threaded bosses are where they need to be for the oil filter cannister and ignition coil. I'm guessing that's the problem. One coolant hole is for the temp senders and the additional one is for the heater. If you want symmetry go with earlier heads and do the needed mods to bolt them to the late block.
    F-ONE and gimpyshotrods like this.
  3. Budget36
    Budget36
    Are you referring to one with just EAB and the other with EAB ****x?
  4. Darin Younce
    Darin Younce
    YES
  5. Budget36
    Budget36
    I didn’t mean to sound like I actually know about them, but it was what I noticed @tubman might know? For sure if posted on the FordBarn they would as well.
  6. trevorsworth
    trevorsworth
    They match fine. EAB heads aren’t symmetrical.
  7. Darin Younce
    Darin Younce
    Thanks , never had a set before these , wasn't sure.
    trevorsworth likes this.
  8. 19Fordy
    19Fordy
  9. Well, one has holes for the oil filter and they are left and right so casting numbers are bound to be different.
  10. Zax
    Zax
    I've been curious about that as well. Why are some EAB heads stamped with just EAB in the center and others are stamped EAB followed by a string of numbers below the plug hole?
  11. F-ONE
    F-ONE
    from Alabama
    It will haunt you forever....You'll have nightmares about EAB on one head and EAB6049B on the other. Why torture yourself? This is where I can help. Send them to me and I will properly dispose of them, so no one else will ever have to go through this trauma.
    The cost of shipping them to me is a small price to pay for a lifetime of comfy, sleep filled nights.
    Remember, I'm here for you.
    Truckdoctor Andy and Budget36 like this.
  12. 51504bat
    51504bat
    Sure you're not from the gov'ment and here to help?
  13. Fortunateson
    Fortunateson
    Grind off what you don’t like...
    Callmaker likes this.
  14. X38
    X38
    I just wish some of you guys would know the difference between numbers and letters that are actually stamped and ones that are cast. Like on these heads. They are not 'stamped.'
    tubman likes this.
  15. razoo lew
    razoo lew
    from Calgary
    So just a question- Why does it matter?
  16. tubman
    tubman
    Do you really have to ask the question?
    I wouldn't let anyone who couldn't tell the difference between stamped and cast numbers within 100 feet of anything I owned.
