Missing, backfiring 350 SBC
Discussion in 'The Hokey Ass Message Board' started by PunkAssGearhead88, Oct 4, 2007.
  1. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Got a belly****on 350 SBC, its missing at idle, under accleration wide open throttle, its also backfiring out of the carb. I got all new plugs, new wires, new HEI,fuel pump, filters, rebuilt carter AFB 4 bbl. also tried swapping with and another carb and no luck. I was thinking cam getting worn or bad valve, whaddya guys think?
  2. Ben'sAuto
    Ben'sAuto
    from So Cal
    check your spark plug wires, and make sure you've got the right wire going to the right cylinder....
    maybe?...
  3. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    not possible, it was running fine for a while, plug wires have always been in the correct firing order.
  4. F&J
    F&J
    Pull the valve covers and watch for valves that don't move....sounds like the typical no lobe cam.
  5. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Check the plug wires anyway. Somebody might be screwing with you.
  6. specialk
    specialk
    try this one on, too much vacuum advance. When the dizzy goes too far, this is exactly what you get.
    Simple test too, just disconnect it and don't forget to plug the vacuum into the carb too :)
  7. Roothawg
    Roothawg
    Back firing where? Carb or exhaust?
  8. lewislynn
    lewislynn
    bad intake valve...Do a compression test.
  9. lewislynn
    lewislynn
    OH! What's a "bellybuton 350"?
  10. RugBlaster
    RugBlaster
    Second F&J......flat cam
  11. Scotch
    Scotch
    Check for a broken valve spring, too. Also- double check for a rocker stud pulling out, unless you've got screw-in studs.
    ~Scotch~
  12. backfiring outta the carb means cam or valves most of the time.
  13. What did you gap the plugs? I had a similar problem with bad miss and I had plugs gap too close. With HEI you can go .050.
  14. old dirt tracker
    old dirt tracker
    from phoenix
    old timer is right, out the carb is cam/valves, out the exhaust is elect. plugs/wires/timing ect.
  15. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Good idea!
  16. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    I was thinking the same, just wanted to make sure I did not possibly overlook something simple as I sometimes do.
  17. The Shocker
    The Shocker
    Had a 350 in a pickup once that developed a pop every now and then out the exhaust on one side.Drove it that way for a year or so when i was a broke teenager ,till it got so bad i just pulled the plug wire off and drove it that way for another month.When i got the money to rebuild it finally ,it turned out to be a split exhaust valve that was shaped like a V from being slammed up in to the valve seat .I dont know what keeped the keepers on the stem ,cause i could almost take the spring off with my hand since the valve was getting pulled higher and higher from the split.I would sure check it out if you plan on using the motor .If it has a valve like mine did on the intake side(sounds like intake popping through the carb) it could drop the keepers and valve .A simple compression check with a cheap gauge will tell you witch cylinder is doing it...
  18. Ray Frey
    Ray Frey
    from Arizona
    Sounds like Flat cam on Exhaust Lobe
    Happens on those usually about 40-60 thousand
    Check with Va***e gage if fluctuating
    Pull valve covers look for rocker not moving
    Or look for push rod off rocker or pulled rocker stud
    Ray
