Technical missing channels in drivers door '32 Ford 4dr
Discussion in 'Traditional Hot Rods' started by dwollam, Sep 7, 2023.
  1. dwollam
    dwollam
    Yesterday I was made aware the drivers front door on my '32 Ford 4dr is missing the 2 metal channels that the widow fussies set into. Are those available or do I need to build them? P***enger side has them. Any pics or info would greatly appreciated!
    Dave
    Link to the '32 below.
  2. nochop
    nochop
    from norcal
    IMG_6149.png These? I picked up a pair for a 5 window, I do not know if there is a difference
    dwollam likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Summit has them,there is a slight difference in the 5 window door and the fordor but these will work. HRP
    dwollam and nochop like this.
  4. dwollam
    dwollam
    Thanks guys! Much easier than making them!
    Dave
  5. dwollam
    dwollam
    Just looked at UP and they show the above number for 32-34 trucks and B20017 as being for tudor, fordor and 5 window.
    Thanks again for the info guys!
    Dave
  6. 19Eddy30
    19Eddy30
    from VA
    I would like to know how they where installed on a moving ***embly line,
    I did a 5w (original missing )
    Doors off car , they where pain in A$$ & time consuming,,
    @ least the way I thought the way to Install :mad:
    dwollam likes this.
  7. dwollam
    dwollam
    Sooo, is there 2 in each door and if so are they the same?
    Dave
  8. krylon32
    krylon32
    from Nebraska
    There is only one of the bolt in channels located in the back of the door. The front channel is spot welded to the front inside of the door and is deeper to compensate for the rear slant of the front edge of the gl***. The pickup and closed car rear bolt in channels are slightly different and do not interchange.
    dwollam likes this.
  9. dwollam
    dwollam
    Thanks @krylon32 . My front one is missing so I guess I'll have to make one.
    Dave
