On a juice brake conversion for a model a, why in Les Andrews book does he say to not use mismatched backing plates on the car and why can’t you use 39-41 backing plates with 46-48 drums and vice versa? RE: backing plates - what’s the issue if you use early plates on the front and later in the rear? In both sections, it’s doesn’t explain WHY you cannot mix parts. Why can’t you mix backing plates front and rear and what’s the issue with drum and backing plate compatibility?
Thanks. That’s my****umption, fronts and fears can be diff year. still curious why the drum and backing plate have to match year. Both drums have an I.D. of 12”. ****ume the braking surface is wider one year to the other?
