Technical Mixing different solid roller lifters
Discussion in 'The Hokey Ass Message Board' started by Twiztid Ben, Jul 28, 2017.
  1. Twiztid Ben
    Twiztid Ben
    Quick question, i was tearing down my 355 and noticed that 2 sets of my solid roller lifters were different brands. 4 are crane cams and 14 are crower. Im guessing who ever had/built the engine before must have damaged some. Im just wondering if this will cause a off balance somewhere down the line or good to go back in.
  2. mohead1
    mohead1
    Good to go
    Sent from my SM-G900V using Tapatalk
  3. lothianwilly71
    lothianwilly71
  4. mohead1
    mohead1
    Engine will never know the difference, ensure they are the type w pressurized oil to the roller.....or consider new ones if you are running them on the street
    Sent from my Venue 8 3830 using Tapatalk
  5. 4 of one and 14 of another might be problem. :D
    Happydaze, Montana1 and squirrel like this.
  6. models916
    models916
    Push rod length and valve train geometry may be off on the different than built versions.
  7. Rex_A_Lott
    Rex_A_Lott
    Installed spares.:)
  8. mohead1
    mohead1
    Sounds like a possible failure and replaced w whatever was cheaper at the time....if standard replacement-- like to like then shudnt be pushrod length issues. Common sizes are stock height or tall type for using on late model blocks (hydraulic roller factory style). Roll engine through by hand, set lash, watch rocker on valve stem and see if travels properly. Doubt a pushrod issue, but check the relationship
  9. Twiztid Ben
    Twiztid Ben
    thanks guys and correction was 4 and 12 lol.I figured all was good but never really messed with roller so wanted to double check..
  10. tubman
    tubman
    I broke a roller rocker in a SBC I had in a boat 15 years ago. I replaced it temporarily with a stock rocker because that was all I could find on a weekend. It was still in there when I sold the boat 5 years later, and the guy that I sold it to hasn't said anything, so I'll bet it's still in there.
  11. That's a very logical guess.
    When those after market roller lifters fail, where's the pieces go?
  12. mohead1
    mohead1
    All over....lol. It wud have wiped the cam probably.....
  13. Exactly
