Hot Rods Moal BRAKE PEDALS
Discussion in 'The Hokey Ass Message Board' started by mandriano, Jan 6, 2015.
  1. mandriano
    mandriano
    Any one familiar with Moal coachbuilders brake pedal ***embly. Specifically how it mounts to firewall, and if you have to use dual master cylinders. Also does it require a brace from the lower dash to the firewall
  2. 1-SHOT
    1-SHOT
    from Denton
    Call Moal they are good to deal with.
    HEMI32 likes this.
  3. gnichols
    gnichols
    from Tampa, FL
    ^^ Ditto. Best advice. Gary
  4. mgtstumpy
    mgtstumpy
  5. seb fontana
    seb fontana
    from ct
    Yeah, mounting looks scary but the instructions probably say to add a plate to the firewall to spread the load out & and re enforce, brace to dash wouldn't hurt..Because the listing says balacne bar you will need two [single piston] master cylinders..Price is killer [killer as in I wouldn't buy] IMO..
  6. $1K for some billet bling? I don't think so....
  7. Attached Files:
  8. krylon32
    krylon32
    from Nebraska
    I've done a pedal setup that combined Moal style pedals on a Willwood bracket. Used polished CNC master cylinders. I put a 3/16 reinforcing plate on the back of my deuce firewall seemed to work fine. My problem with the Ansen style pedals I felt they were a little short and mounted the master cylinder to low on the firewall plus I wanted the three master cylinders to run both ends of the car and the clutch and the Ansen pedals at the time only used the Chevy PU style MC. That was several years ago and there may be some thing better out there now. Lucky Seven looks like a good setup.
  9. Bruce Lancaster
    Bruce Lancaster
    I believe the traditional swing pedal setup was two complete units from the first Fords that had swing pedals, the '52-4.
    There was a commonly available speedshop kit that contained a simple bracket to fit top flange of '39 style transmission and a clutch cylinder and clevis, probably a part from a period pickup truck.
  10. Unkl Ian
    Unkl Ian
    Use a custom clevis, to operate one master cyl.
  11. thirtytwo
    thirtytwo
    ***us makes a short run every now and then that are made nice and sturdy and resonably priced ... A customer bought some from an unknown source and they were really bad I could bend the pedals with one hand ..buyer beware
  12. green73
    green73
    if you want the Moal look on the cheap, here is my suggestion. I recently did the following with the frame mount Pete and Jakes clutch/brake pedal ***embly. I just wanted to liven up the pedal arms from looking like laser cut steel plates. Chose whatever reproduction like the "Luckys" above. Layout a lightning hole pattern that you like and get to drilling with your drill press. Next find a length of bar stock at a width of your choice and put a few holes down the center not bigger than the pedal arms are thick. Get out your c-clamps and weld the bar stock, or whatever you chose perpendicular to the pedal arms on both sides. and grind the plug welds smooth. You end up with the drilled I-Beam look at much cheaper. For your lightning holes you can alternate hole sizes, bevel the edges, etc... for a personalized effect. Yep it takes some work, but what project doesn't.
  13. mikegt4
    mikegt4
    from SW Ohio
    Yepp, I would think that the typical Moal client makes that $1000 in about the same time that it takes you to drink your morning coffee.
  14. 340HilbornDuster
    340HilbornDuster
    Yikers!!!1000
    That's what i paid for my Phaeton w. ***le, frame, rear axle, front and rear Bonez & Springs.
    Rusty & crooked but still...
    Pedals - I just use my b*** drum pedal..(Not Aircraft spec though!)
  15. Those are nicely refined pedals. Pricy but having designed my own and knowing the time involved, you are paying for some pretty serious head scratching.
