Technical Mock up question
Discussion in 'The Hokey Ass Message Board' started by dann57, Jun 18, 2014.
  1. dann57
    dann57
    from Missouri
    Ok so I thought I knew how I wanted to mock up this motor but now after I have it in there to me it looks like its up pretty high in the frame. The reason I set it up so high was so the fan would draw air into the radiator good. Is there a standard or something on how high your motor sits in the frame? For you guys who have done this alot I'd like your input. Heres a couple pics
  2. scrap metal 48
    scrap metal 48
    I usually work with Chevy engines but I always have the radiator in place and the water pump and fan blade in place to get the right height and location of fan blade to radiator right...
  3. dann57
    dann57
    from Missouri
    thats what I did it just looks high to me
  4. txturbo
    txturbo
    I agree.....looks too high.
  5. bartmcneill
    bartmcneill
    from Ada, OK
    Looks about 3 inches high.
  6. dann57
    dann57
    from Missouri
    the reason I'm asking this is if I leave it this high my cross member will be in about in the middle of my frame instead of being even with the bottom or below the frame and if its any lower my fan will be alittle below the radiator
  7. I think the low angle pics are making it look high. can you take some from higher up and further away?
  8. dann57
    dann57
    from Missouri
    Here is one with the bare block
