Mockup....Project WARPIG...........
Discussion in 'The Hokey Ass Message Board' started by Littleman, Jan 5, 2008.
  1. elcornus
    elcornus
    Thats some wild rearend set up there, never woulda thought of that solution, but I'd use BIG chain instead of the belts, seems they'd shear off the belts teeth at the hit of the throttle. maybe not though???
  2. BAD ROD
    BAD ROD
  3. Jeem
    Jeem
    Alliance Vendor
  4. elcornus
    elcornus
    Yeah, so you can do this!!!!!!
  5. elcornus
    elcornus
  6. Don Moyer
    Don Moyer
    I just want this (Autocad?) program so I can play on my computer. I cant draw a stick figure and would really like to transfer some of the ideas in my head on to paper.....
  7. gbones32coupe
    gbones32coupe
    mount a park bench seat on the roof and through some wagon wheels on it and it will be a looker. haha would make a good dodge advertisment THAT THING GOT A HEMI IN IT!!!!!!!!!
  8. stragedy
    stragedy
    Don't those guys that make wheelie cars have a special transfer case for doing what is shown in those illustrations ?
  9. Yeah, a very expensive V drive!
  10. 50ford
    50ford
    from enid
    Ok I have a dumb question but my curiosity is running wild with ideas. What would the pinion angle on the 4x4 set-up be and am I correct in ***uming you would have to run multiple (ie mid or front) and rear motor plates to keep the clearance issues from becoming catastrophic due to torsional flex? This is the idea a friend of mine got me hooked on with the advent of the HA/GR. I got lots o' ideas but still getting skill.
  11. kustombuilder
    kustombuilder
    from Novi, MI
    if it were just about anyone else Dave, i'd say you were ****in NUTS. since it IS you and i KNOW your nuts it's ok though :D. i'm sure it'll turn out BAD***!!... building a midengined car has been onj my mind since childhood so some of the ideas i've seen here have REALY gotten my attention.
  12. luckydevil
    luckydevil
    This is sweeeet!!! I hope you get it done for the Rock & Race...
    You can always use a 4 door sedan body to gain some room.
    Toby from Dragway 42 might be able to help you out with a v drive. He has built dozens of wheelstanders. I know he built and raced one called Night Rider. It was a Camaro body and he sat just about where the dash is. I think it would be a similar set up for what your doing.
  13. attitudor
    attitudor
    from Finland
    Check out this crazy Finn...
    First he put a blown Toronado Big Block with NOS into the trunk of european Ford wagon. Not cool enough, swapped the driveline into a Chech Skoda. Not fast (?) enough, built a trike around the motor.... :eek: :D
    http://www.pjp.fi/index.php?sivu=2&alasivu=0&tyyppi=Omat
    --mika
  14. AHotRod
    AHotRod
    Dave,
    I'm sure that our own Don Garlits has explored most every option for doing what your continplating. Why not drop him an email with some pictures, you may be surprised as to what he has in his shop.
    If you have ever had the pleasure to tour his museum, and his shop, you then have seen many ways to transfer power.....some will work, some do not.
    I get where you are going with this, as I to march to the same twisted drummer.
  15. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    this is grrrrrrrreeeeeeeeaaaaaaaaaatttttttttttttt!
  16. I love the cadence story.
    This is like the car, I can't for the life of me remember his name, with two '40 Ford hoods made into the nose. Jack Chrisman?
  17. The Chrisman Bros built the 30 coupe you are thinking about, Art and Lloyd.
    It also sported the first set of Moon spun disc's, it also originally ran a Merc flathead before the Hemi found its way in there.
    Imagine ripping along the salt a 200mph with your nose inches from the windscreen!
    Man that car does all sorts of good things to my wiggly bits!
  18. sammyg
    sammyg
    You're putting an ATLAS... Into a hot rod?!?!?! :eek:
    You going to be going for some insane crawl ratio? :eek:
    Cool though... :rolleyes:
  19. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    You can run it in the 1:1 ratio....................Littleman
  20. ChopperMark
    ChopperMark
    from Aloha, OR
    When you described the project this is what I thought of. The 40 Ford windshield might give you a little more "headroom" :D
  21. Cshabang
    Cshabang
    this is awesome....can't wait to see it along side deaths doorstep, and the truck
  22. sammyg
    sammyg
    Having it built with that ratio only or are you triple sticking it (IIRC thats how they are. I use a ****er 18 myself...) I'd be worried about the wear and tear going on inside of it, but ATLAS is renowned for their cases so who knows.
  23. wicked willys
    wicked willys
    from ne ohio
    Can't wait to see this project progress. Love the way you think Littleman!!!!!!!!
  24. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    From what the people @ Atlas have told me, they said if I kept it shifted into 4wd high it will be 1:1 ratio.......I described how I wanted to use their peice......and all I got was some awkward silence....and a well yes I guess you can use it to do that.......I am not no 4wd guy at all, the closest I ever got was putting a Military Hum. to the test..awsome vehicles not the street versions.............I am reading up on all the rock crawler, v-drive drag boats and sand buggies configurations........And what I have learned they are doing some kool stuff...Littleman
  25. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Awsome drawing ChopperMark!!!!.Thanks for doing that........we are kinda thinking the same. I have been thinking all along that I must do the 40 ford hood front end and a very similiar window treatment for it cheats for more head room and compliments the nose treatment, I also have something planned for the roof.....Thanks again ,Littleman
  26. mikew
    mikew
    That's inspiring... can't wait to see how it turns out.
    Mike
  27. ANewBeat
    ANewBeat
    from Floriduh
    This is going to be so cool.
  28. ChopperMark
    ChopperMark
    from Aloha, OR
    Littleman: you should tell me what you have in mind for the roof. I would love to bust a out rendering or two. PM me with any ideas you have. I haven't drawn anything in a long time and this project is inspiring.
    Death's Doorstep is a crazy car too, but what I love most is the story about the dedication to your step-dad.
  29. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Thanks for the offer ChopperMark........and thanks for the kind words about DeathsDoorStep...Littleman
  30. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Don Moyer mounted my new Hurst 10''x16''slicks yesterday....Thanks Don........and Thanks to Hotrodrubber at Hurst!!!!!! they look great.....So this project now has a full set of shoes......Littleman.......nothing like Magnesium on all four corners and only a pair of rear brakes only...for Drag purposes only of course.......
