Projects Model A aprons
Discussion in 'Traditional Hot Rods' started by Martinbuilt, Sep 16, 2024.
  1. Martinbuilt
    Martinbuilt
    I've a question for those of you running aprons on a fenderless car.
    Do they flop all over the place?
    Have you built any sort of bracing? If so, post a photo of what you came up with.
    I like the idea of hiding some of the mechanicals, but I hadn't realized how thin those aprons were.
    Thanks
  2. ironandsteele
    ironandsteele
    I have run them on a few cars over the years. No bracing.
    ironandsteele.com​
  3. 1ton
    1ton
    I've thought about this for some time.
    I ***ume you a not using running boards.
    But to cover and protect the brake rods and to give the bottom of the car a little shape.
    You already know that they are going to move a little bit.
    So why not make up some light duty braces for a little support.
  4. 31Apickup
    31Apickup
    The stock aprons are pretty stiff, although I’ve seen some of the repro ones made of lighter gauge metal so those may flopp some.
  5. Martinbuilt
    Martinbuilt
    Mine are originals, so maybe they'll be okay.
    Juice brakes, so no brake rods.
    I bought a Boling bros battery/master setup.
    It's mostly that I want to hide.
    Thanks
  6. '29 Gizmo
    '29 Gizmo
    from UK
    They sit on the running board brackets. Cut the brackets back and make a tag to bolt them to the stub of the bracket.
    Tim and Stan Back like this.
  7. 51 mercules
    51 mercules
    The former owner of my roadster made some brackets that bolted to the bottom of the frame and used the existing bolt holes in the splash apron. In the pic you can barely see the bolt in the front and back of the splash apron.[​IMG]
    Stan Back, Tim and flatheadpete like this.
  8. Martinbuilt
    Martinbuilt
    Great car, thanks for the info
    51 mercules likes this.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    I love the look of a fenderless A with the splash aprons.
  10. 51 mercules
    51 mercules
    Thanks! You're welcome!
