Hot Rods model a aux transmission
Discussion in 'The Hokey Ass Message Board' started by 1955 f350, Oct 26, 2015.
  1. 1955 f350
    1955 f350
    I was at a junk yard to day and found a truck with aux transmission in it was a 1928 or 1929 it had a peddle on it for shifting it. is it for overdrive or under drive
    this is one you hook up to the stock transmission and it has a cross member to hold the back of it look like stock
  2. Model A Gomez
    Model A Gomez
    Underdrive with straight cut gears, not worth much unless you are restoring a truck. Even then they really aren't desirable, AA trucks had really low gears.
  3. 1955 f350
    1955 f350
    so is it under drive or over drive ?
  4. F&J
    F&J
  5. seb fontana
    seb fontana
    from ct
    Local AA has one...Can be real interesting [re: busy!] shifting it and the 3spd..
