Model A Axle Options - NEED ADVISE
Discussion in 'The Hokey Ass Message Board' started by BenDover, Sep 26, 2009.
  1. BenDover
    BenDover
    from SGV, CA
    Hey Fellas, I'm new to A's and need some basic advise on what type of front axle I should/can use. Here's where I'm at - I just bought a 30/31 Roadster body and frame. The frame has all cross members and axle components still in place - it's bare BONE STOCK and in great shape. I also have a good friend that's giving me a great deal (steal actually) on a 40 Ford font dropped axle with everything minus the backing plates. Here's where I get stumped... Should I drop and/or modify my stock axle/front end and run with the A equipment or go for the 40 front dropped axle my buddy has? I want to build something w/out fenders that is nostalgic/traditional using a 8BA Flathead and keep cost on the low side as best I can. I've ordered "the book" but hear that it mostly references 32's. Also, if anyone has a swapping list or if there is a post that already address this I would appreciate it. I've done the search's and cant find anything. Please don't ask about the rear end I plan to use because I haven't even get to that yet... Suggestions for the rear would be also appreciated if you have them.
    Thanks ahead of time!
    JP
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  2. you could go with a banjo rear from a 40-48 ford car?..it'll have juice brakes and enough clearance and will hold up to the flathead.I would definately go with the '40 ford front end model A brakes were all mechanical and marginal at best.If the '40 ford front end you have is complete with axle and ,hubs,kingpins i would go with that and get some backing platespretty easy to find,other wise you can get spacer rings from Speedway motors that let you use juice brakes with Model a front spindles...are you suiciding the front end or cross steering it?(vega)...
  3. BenDover
    BenDover
    from SGV, CA
    I don't know what I'm doing at this point... I'm mainly looking for info on what works and what doesn't or hasn't for anyone else. I have a steering column (cross steering) that was thrown into the deal when I bought that project but again, i don't want to rule out any other options.
  4. 296 V8
    296 V8
    from Nor~Cal
    Id go
    1. Dropped A axle
    2. A spring
    3. Split 40 wishbone
    4. 40 spindles and brakes
  5. scrap metal 48
    scrap metal 48
    1940 rear ends are a little narrower and look better than 46-48s on A's........
  6. gashog
    gashog
    Alot depends on how much lowering you are looking for. IIRC, the later axles have a wider track that you will have to figure in if you go that way. I used a stock 32-36 axle with a 2" drop over the a axle to give you seome ideas (see my build thread).
