Technical model a axle
Discussion in 'Traditional Hot Rods' started by hugene, Jul 19, 2014.
  1. hugene
    hugene
    from pineola fl
    Could someone tell me how much you can drop a model A axle and not split the wishbone ?
    Thanks Gene
  2. Texas Webb
    Texas Webb
    It's done all the time.Splitting the wishbone was done usually for engine or trans clearance.
    I'm not splitting mine.
  3. brokenspoke
    brokenspoke
    I dropped my 32 axle to 4 inches and didn't split the wish bone
  4. HOTRODPRIMER
    HOTRODPRIMER
    Splitting bones is only necessary when guys need clearance for bigger transmissions. HRP
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Dropping the axle has nothing to do with the wishbones. Only the ends of the axle move up but the mounting perches for the wishbone stay in the same relationship to the frame as they were when undropped.
    Don
  6. Runnin shine
    Runnin shine
    Dropping your axles ends doesn't change the placement of your wishbone. But you can run into tie rod and drag link issues. Depending on how much the spindle will be raised after the axle is dropped you may need to reposition these pieces. If you reverse your leaf spring end or remove leafs this will raise the wishbones placement thus putting it closer to the frame at a rest. Now if you hit a bump it can "bottom out" sooner because these parts will have a head start.
