Technical model a banger exahust header
Discussion in 'Traditional Hot Rods' started by dmdeaton, Apr 3, 2018.
  1. dmdeaton
    dmdeaton
    I have a set of Charlie's cast iron headers. I like them a lot and plan to use them on my build. Problem is his single carb manifold will not work with these. The intake needs to have a upsweep in the pipe as it comes out of the head to clear the iron headers. His twin carb intake works with this setup. I really don't want to put a dummy carb or block off plate on a twin carb intake. I guess I may be out of luck using these headers. Who makes a good set of tube headers?
    Here is the link to Charlie's headers.
    http://www.secretsofspeed.com/header-images
  2. dmdeaton
    dmdeaton
    I do have his ROOF 101 Cyclone Four Port OHV head and plan to use these headers with this setup, but this is later down the road.
    Here is a pic of his headers with his 2 carb intake.
  3. patmanta
    patmanta
    from Woburn, MA
  4. dmdeaton
    dmdeaton
    That sure looks like it would clear. It has the upsweep. Not as ***y, but will get the job done.
  5. patmanta
    patmanta
    from Woburn, MA
    It's basically a stock intake, so, yeah. All the other singles seem to come straight out. I've been looking around too because I have a running B setup out of a 34 pickup (with the 90° header) and I'm weighing my options for bolt on upgrades.
    I wouldn't spend a lot on a single intake if you're just going to drop that OHV setup on there anyway. You'll probably want more air after that. You can always sell the single when you're done with it.
  6. dmdeaton
    dmdeaton
    I am going to try a stock intake flipped upside down and see if it has clearance. If it does I will order one of these. It is aluminum.
  7. dmdeaton
    dmdeaton
    I am almost thinking of snagging a set of their 4 into 1 cast iron headers. Not too pricey, wonder who is making these for them?
  8. burl
    burl
    from Minnesota
    Running a single 97 with a set of reds headers.Most of the guys I have talked to running multiple carbs are not claiming to have to much success with it.Looks pretty cool but most claim a single 81,97,or 94 makes the car run the best.Trying to keep mine as simple as possible. banger.jpg
  9. dmdeaton
    dmdeaton
    Snyder's is out of stock on that intake with no date to restock. Foundry problems.
