Model A battery ground
Discussion in 'The Hokey Ass Message Board' started by Smilin Jack, Feb 16, 2013.
  1. Smilin Jack
    Smilin Jack
    I just bought a nice old original '30 Model A. I haven't cranked it yet but read where the 6 volt battery is supposed to be positive ground. It isn't hooked up like that though, it's neg. ground. does this make a difference. Has the privious owner got it backwards? Getting ready to crank the old gal.
  2. Homemade44
    Homemade44
    Stock Model A's were Positive ground.
  3. Smilin Jack
    Smilin Jack
    It supposidly was cranking and running like this. Is it better to change it back to pos. ground. Where in ms. are you? I'm near Corinth.
  4. Smilin Jack
    Smilin Jack
    If the battery is hooked up with a neg. ground, will it affect the cranking? A pos. ground is new to me.
  5. Smilin Jack
    Smilin Jack
    I guess I'm just trying to determine if it was meant to be neg. ground for some change that was made or was hooked up wrong.
  6. junk yard kid
    junk yard kid
    Check how your coil is hooked up. If the + goes to distributer its positve ground. If - to dizzy than negative ground.
  7. Smilin Jack
    Smilin Jack
    It's definitely supposed to be pos ground. Just not hooked up that way. Just bought it and trying to get it going.
  8. junk yard kid
    junk yard kid
    It just wont get as much spark. Just switch them around and start that thing up.
  9. Smilin Jack
    Smilin Jack
    Thanks. Evidently it's not a big deal.
  10. Mr48chev
    He beat me to it.
    Yes it is supposed to be wired + ground with the 6V but the PO may have changed it all over to - ground in the past.
  11. tb33anda3rd
    tb33anda3rd
    turn the head lights on and see which way the ammeter moves, if it goes to positive you are hooked up wrong.
  12. 40FordGuy
    40FordGuy
    Ford 6 volt systems were pos. ground, thru the 1955 model year. For 56, Ford joined the 12 volt, neg ground world.
    Happy Roddin' 4TTRUK
  13. Homemade44
    Homemade44
    Jack, sorry I didn't get back to you sooner, left after I responded. I am in P*** Christian, right on the Gulf.
  14. Smilin Jack
    Smilin Jack
    I'm on (literally) the Ms/Tn line.
