Hot Rods model A below decklid panel
Discussion in 'The Hokey Ass Message Board' started by hot rust, Mar 12, 2021.
  1. hot rust
    hot rust
    question i purchased a below decklid panel for a 29 roadster off e bay seller, got it in and a few weeks later i went to install and it is not as tall as my original one,which is over 9 inches tall and the one i received is 7 1/2 inches tall. is there a difference in coupes and roadster panels? for a 28-9 thanks for your help
    Stogy likes this.
  2. Stogy
    Stogy
    ...that sucks...you mentioned Coupe so let's see...:oops:
  3. rusty valley
    rusty valley
    how do they list it in the vendor catalogues, all the same, or different?
    Stogy likes this.
  4. Stogy
    Stogy
    What's it called I know the one up top is called the Tulip Panel as it looks just like one eh!...:D
  5. rusty valley
    rusty valley
    I believe its the panel below the deck lid, just as the poster said, Stogy
    Stogy likes this.
  6. Stogy
    Stogy
    Rusty I was just wondering what the proper name is for the under trunk panel not the tulip...
    I was joking the tulip panel looked like a tulip...not
    rusty valley likes this.
  7. A 2 B
    A 2 B
    from SW Ontario
    Just for a point of reference, a '30 coupe panel is 9 3/8" tall. It's called a "rear outer panel".
    Lloyd's paint & glass and Stogy like this.
  8. Stogy
    Stogy
    My Apologies it is via Brookville called exactly what @hot rust called it...:oops:
  9. Stogy
    Stogy
  10. A 2 B
    A 2 B
    from SW Ontario
    28-29 Coupe & Sport Coupe 7 3/4"
    28-29 Roadster 9 1/2"
    29-31 Cabriolet 9 3/8"
    These measurements are from Mike's. Differing slightly from my measurement of a 30-31 Coupe & Roadster they list 9 1/4".
    rusty valley and Stogy like this.
  11. Stogy
    Stogy
    There are so many threads on poor fit so that may explain your panel difference @A 2 B
    Just Gary likes this.
  12. Corn Fed
    Corn Fed
    Yep, in 28-29 the roadster is taller than a coupe.
    If the original top inner horizontal brace in the one you took out is still good, you might want to reuse it if you get another repro panel. Some of the repro panels are pretty cheap and their braces suck...so use the old one if you can.
  13. Stogy
    Stogy
    This Goose has been cooked...hopefully he can trade it off...or return it as Ebay has policies if it is not as described...they're $84 bucks or so...I hope he didn't pay too much for it...
  14. A 2 B
    A 2 B
    from SW Ontario
    Slight differences are common with all aftermarket pieces as well as orginal Ford parts depending on the origin and date of manufacture. I measured one from Howell's that I just installed. With only a 1/8" difference from each seller, that is nothing to worry about. The seam sealer will make that slight difference disappear. The real difficulty with those panels is the "buckle twist" they can develop if care isn't taken when installing. Very visible in the finished panel if not corrected on assembly. I agree on the cheapness of the re-pop bracing and supports but we tend to use what we can get if its not feasible to make your own or re-use the originals.
    It's a bummer the OP got the wrong one.
    stillrunners and Stogy like this.
  15. Stogy
    Stogy
    @hot rust you could be different and run Whatcha got...and add a lid extension to make up for it...maybe it looks better...more room for putting in lawn chairs and a 12 of Water or any desired beverage...:D
