Technical Model A Bendix Drive
Discussion in 'Traditional Hot Rods' started by BazzaM, Dec 12, 2022.
Tags:
  1. BazzaM
    BazzaM
    Does anybody know what the Head Sleeve in the above diagram do?
    The Head Sleeve is hidden inside the big spring and normally not seen. It engages with the Driving Head but just spins on the Bendix Shaft, it doesn't drive anything.
  2. Clydesdale
    Clydesdale
    does it centre the spring around the shaft?
  3. Budget36
    Budget36
    Maybe @e1956v has seen a few come through the shop?
  4. e1956v
    e1956v
    Alliance Vendor
    It helps prevent drive flex in the spring, stiffening up the drive in the middle of the spring. They commonly break which puts more pressure on the spring itself under engagement.
    twenty8, Budget36 and dirt t like this.
  5. BazzaM
    BazzaM
    Thanks for the reply but, no sorry, that doesn't seem right. The head Sleeve has an OD of 1" while the big spring has an ID of 1.3". So there is a large gap between the two. The spring couldn't flex that much in the middle to contact thd Head Sleeve for it to help support the spring.
    I had a theory that when the big spring got wound up it would shorten in length and maybe this Head Sleeve limits the shortening. Or maybe it acts as a clutch and locks the ***embly so the big spring cannot keep winding up.
    I don't know, still open to ideas. But I do know I just spent hours making 2 new ones. It is hard to get Bendix units for the early 1/2" starter shafts.
  6. e1956v
    e1956v
    Alliance Vendor
    My bad I don’t know what I’m talking about
    Outback and twenty8 like this.
  7. alchemy
    alchemy
    Ha! Well Bazza, if you already knew more than the experts, why did you ask? Too bad there's nobody here with decades of experience rebuilding auto generators and starters.....
    Outback, twenty8 and Budget36 like this.
  8. e1956v
    e1956v
    Alliance Vendor
    I apologize for the smart *** response.
    twenty8, 57 Fargo and Budget36 like this.
  9. BazzaM
    BazzaM
    I'm still mystified what it does. Mine were just ideas I came up with.
    Still open for suggestions. It must be there to do something but what?
  10. twenty8
    twenty8
    I'm mystified that @e1956v gave you the answer and you rejected it.
    You do know he has been a speedometer and auto electric rebuilder for 40 plus years, right ???
    Outback, Budget36 and 57 Fargo like this.
  11. RAREBIKE
    RAREBIKE
    Definitely keeps the spring from breaking, test it by not using it and you will see.
  12. BazzaM
    BazzaM
    Thanks for your replies, you've convinced me. Sorry to come across ungrateful for your various replies.
    Outback likes this.
