Hot Rods Model A body mounts
Discussion in 'The Hokey Ass Message Board' started by scoop, Mar 21, 2020.
  1. scoop
    scoop
    Anybody use other ways to mount the body besides wood? My body is unchanneled.
  2. pitman
    pitman
    I trimmed out 57 Chev biscuits, front engine mount isolators. Later, used vette rear spring bushings.
    Nailhead Jason likes this.
  3. Jalopy Joker
    Jalopy Joker
  4. winduptoy
    winduptoy
    Have made them out of old rock crusher conveyor belt...its a ***** to cut
  5. Never2old
    Never2old
    from so cal
    Are you trying to save trees or what?
    All of the original blocks were still working on my rpu but they were ugly so I put in new ones. Cheap.
  6. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Wood on daily driven A model for over a decade......
  7. Almostdone
    Almostdone
    Doesn’t directly answer your question, but I bought new wood blocks and rubber shims for my ‘31 A. Perfect.
  8. dalesnyder
    dalesnyder
    Does the wood raise the subrails off the frame or are they flush to the subrails on the bottom?
    I know you have the webbing, then rubber then wood, right?
  9. rusty valley
    rusty valley
    off the frame very little. the wood sits inside the channel. cant remember now, but i think wood right on the frame for me, no rubber or webbing.
  10. Dino 64
    Dino 64
    from Virginia
    I did webbing against the frame, wood, then rubber.
    Used some metal shins to get the doors aligned
    For whatever it worth, Brookville uses wood mounts although some guys use steel biscuits. I feel you’re risking cracking the body with no cushion at all.
    My 2cts
  11. RB35
    RB35
    Bratton's model A parts sells the oak wood kits. Worked fine on mine. Just painted to preserve and installed.
    pitman and Dino 64 like this.
  12. woodsnwater
    woodsnwater
    from North Al.
    What if your using a 32 frame? Will the wood still work?
  13. Dino 64
    Dino 64
    from Virginia
    Yes, you’ll have to modify the rear one because of the kick up on the 32
    Got mine from Brattons too. Had to modify them all a little to minimize the gap between the frame and body
    woodsnwater likes this.
  14. scoop
    scoop
    This was my next question.
  15. scoop
    scoop
    Far from a tree hugger, this car was restored a long time ago ( very amateur) wood was replaced with pine! So it was poorly done,same with the roof wood.
  16. Dino 64
    Dino 64
    from Virginia
    In my last post, the wood needs to be shaved some to minimize the gap. Only way to completely eliminate it is a cowl mini channel
  17. scoop
    scoop
    Dino,I'm using the Model A frame.
  18. Dino 64
    Dino 64
    from Virginia
  19. woodsnwater
    woodsnwater
    from North Al.
    Sorry Scoop, I sidetracked your thread a little.
  20. wheeldog57
    wheeldog57
    When you have everything all sorted, tighten them snugly with lock washers. It will squeak big time if you don't. I know first hand, hehe
    Dino 64 likes this.
  21. alanp561
    alanp561
    If you can find it, use air dried white oak or air dried ash. Air dried lasts much longer than kiln dried. Don't use red oak at all. It is extremely porous, soaks up moisture like a sponge. Henry Ford had his own white oak and ash forests in Northern Michigan just to supply his production lines.
    wheeldog57 likes this.
  22. scoop
    scoop
    No worries.
  23. RB35
    RB35
    I just cut and split up some ash rounds my neighbor had cut down to eliminate borer worries. Want to carve your own??
    alanp561 likes this.
