Model A body panel questions
Discussion in 'The Hokey Ass Message Board' started by SlappyMcfinklestien, Jun 18, 2012.
  1. SlappyMcfinklestien
    SlappyMcfinklestien
    from Michigan
    I'm in the early stages of re-working the body of my 31 Ford 5window coupe. My biggest question (right now) is concerning the depth of the body/wheel well. My coupe looks like someone might have did a partial tub job. I have a 2-3 rolled metal edge that goes where my inner fender wells used to be. Does anyone know if there is supposed to be a lip in the inside (below the decklid) for the inner wells? I think I can just roll a couple pices and weld my patch panels but I'd like to get it pretty close to where it should be. Any help would be appreciated.
    Thanks
    Mike
  2. junk yard kid
    junk yard kid
    if i understand right, the piece that recesses the wheel well panel goes from almost zero to about 3 inches then back to zero.
  3. skwurl
    skwurl
    They go in about 2 to 3 inches at the top. They are straight up. The body is wider at the top of the wheel well.
  4. SlappyMcfinklestien
    SlappyMcfinklestien
    from Michigan
    Sweet ~ I was kind of confused because the lip looks pretty stock ~ (about 2-3" wide) Thanks for the help.
  5. Fenders
    Fenders
    I just took the rear fenders off of a 31 coupe...
    more or less, +/- a quarter inch, the back is in 1/4"
    the center is in 2-1/2"
    the front is is in 1 inch
  6. SlappyMcfinklestien
    SlappyMcfinklestien
    from Michigan
    Thanks for the pix ~ they help more than anything.
  7. SlappyMcfinklestien
    SlappyMcfinklestien
    from Michigan
    Ok got my first question answered pretty quick so here's a tough one. My 5 window was channeled and then forgotten a couple dozen years ago. Now I have the fun job of adding new subrails and new panels to make it solid. Has anyone gone through this and if so what's the best way to start? I'm thinking on mine the first thing is to rebuild the wood in the top/sides and then flip the body and work from the bottom down to the body. If anyone has insight on this job I'd love to hear some ideas.
    Thanks
    Mike
