Hot Rods Model A bones don't fit
Discussion in 'The Hokey Ass Message Board' started by Coggs_n'_gears, Jul 1, 2018.
  1. Coggs_n'_gears
    Coggs_n'_gears
    Anyone else run into this? I picked up these model a bones and I had this axle I believe is a 37-41. Could I get away with grinding on the axle a bit or should this be done on a mill? 20180624_175341.jpeg 20180624_173710.jpeg Screenshot_2018-07-01-11-20-26-1.jpeg
    Sent from my SM-T530NU using The H.A.M.B. mobile app
  2. scrap metal 48
    scrap metal 48
    Model A bones are weak and need to be modified to get a good caster angle.. In my opinion you would be better off getting later bones that have a little caster built into them and are a lot stronger...
    olscrounger and dana barlow like this.
  3. Unkl Ian
    Unkl Ian
    IIRC, early stuff is 2", later is 2 1/8".
    dana barlow likes this.
  4. Coggs_n'_gears
    Coggs_n'_gears
    Thanks bud [emoji106]
  5. 1946caddy
    1946caddy
    from washington
    ***uming your calipers are correct, your axle spring perch boss is too tall. Model A axle spring perches are 2.250" and 37-41 car axles are the same 2.250". I'm using a 37 axle with model A bones on my latest project and they fit perfect. (see picture). Be advised that if your going to use a traverse spring. the perches are 2" wider on the 37-41 axles and you will need a longer spring ( got mine from Posie). I sent my axle to Sid and he dropped and stretched it to maintain the 48 1/2" king pin to king pin center. set the camber, magna fluxed the axle and bent my spindle arms to match the drop. It even came back painted. I personal would not grind on the spring perch boss but let an expert do it.
    olscrounger and Coggs_n'_gears like this.
  6. RICH B
    RICH B
    Not sure why; but my experience with axles differ from those numbers.
    '28-'31 A axle perch bosses are 2-1/4", '32-'36 axles are 2", and '37 up axles are for the most part 2-1/4"; but it not unusual to find them a little thicker.
    Not a big deal to cut down. A disc grinder will make quick work of it; of course if feel it is necessary, a Bridgeport will do the job.
    Like s**** metal 48 says, A wishbones have their place; but depending on what you are to, later 'bones have a lot of advantages.
    scrap metal 48 likes this.
  7. Unkl Ian
    Unkl Ian
    You are probably right.
