Technical Model A brake drums
Discussion in 'Traditional Hot Rods' started by Matthew Davis, Feb 4, 2023.
  1. Matthew Davis
    Matthew Davis
    Just starting my first A and we're going through getting the mechanical brakes back in good order. Is there a way to identify original steel brake drums from cast iron? I haven't got them in the parts cleaner yet but didn't notice any stamping.
  2. rusty valley
    rusty valley
    Only the late 31's had cast iron drums. They have always been hard to find, very doubtful thats what you have. Cast iron drums have open windows on the front like 32 35 drums, you can see the brakes once the wheel is off
    Outback likes this.
  3. Matthew Davis
    Matthew Davis
    Sorry, I should have clarified. I was thinking they may be aftermarket cast iron.
  4. Hitchhiker
    Hitchhiker
    The stamped steel have a thin edge where they are by the backing plate.
    I think it's pretty obvious. But maybe I'm wrong.
  5. Mr48chev
    The stamped units are pretty easy to tell that they are stamped steel once you study them a bit.. Screenshot (108).png
  6. '29 Gizmo
    '29 Gizmo
    from UK
    I did just the same.. steel ones have a return lip on the edge of the drum. Sometimes they also have a reinforcing band but not always. 99% of cast iron drums on model As are modern aftermarket parts. Good to see someone restoring the original system.
  7. Matthew Davis
    Matthew Davis
    Awesome, thanks guys. The return lip is definitely the clearest indicator for me. There is so much to learn and I'm about 100 years behind.
  8. 4ty
    4ty
    If looking for new ones, contact Randy Gross over on the Ford Barn.
    Paul in CT
