Technical Model A build, what width rear axle to use?
Discussion in 'Traditional Hot Rods' started by HotRodRyan, Feb 6, 2017.
  1. PetesPonies
    PetesPonies
    from Maryland
    That unicorn I would love to see . . . . a 1955 9".
  2. fiftyv8
    fiftyv8
    from CO & WA
    I run a 1950/2 Ford flathead diff behind my 289 V8.
    It is a nice width, light weight, with decent width brake shoes and comes in a 3.7:1 ratio stock.
    Best $50 I ever spent in 1980 and still running...
    Chappy444 likes this.
  3. jackalope
    jackalope
    If you are not too worried about a period specific axle, a great candidate is the late model Jeep Wrangler JK Dana 44. Narrow it to your exact width and have shafts resplined. Pretty much bomb proof. I have a fixture for true-ing the tubes before welding them to ensure bearing hub-carrier-bearing hub are dead true. [​IMG]
    burl likes this.
  4. RICH B
    RICH B
    Seems to me the Bronco axle might not be the best choice. What you really need to do is get those Speedway wheel adapters you mentioned, bolt them up to your '35 wires with the actual tires you are running, Set them under the fenders where you want them to be, and measure between them. Then see if can find a 8" or 9" car rear (4-1/2" bolt pattern that will fit the Speedway adapter) the right size. A Maverick may be close. Another thing, some times it is possible to only narrow one side of the rear, you only need to deal with one axle. If your car isn't together enough to hang rear fenders; just measure the fender width on another A.
    trikejunkie and sdluck like this.
  5. sdluck
    sdluck
    Listen to Rich B
  6. PetesPonies
    PetesPonies
    from Maryland
    What vehicle is yours from? Or are they all teh same width? truck or car?
  7. threewindow
    threewindow
    We used a S10 rearend on our 31 roadster. With the wheel support ring and the spacers you will need , It ended up just right with 35 wires.
  8. 1946caddy
    1946caddy
    from washington
    Since you already have as running,driving Model A , why don't you put on the 35 wire wheels and see what kind of clearance there is and adjust accordingly?
    Just Gary likes this.
  9. Bill Rinaldi
    Bill Rinaldi
    On a model A, I'm in favor of an S-10. Cheap, fits well and unless you beat hell out of it, will hold up well. Narrow enough for your wires and adapters, and narrow enough for just about any wheels you decide on. Good ratios from 3;20's to 3:72 and cheap and really available. S-10. Bill Rinaldi
    pprather likes this.
  10. Chappy444
    Chappy444
  11. Your building HotRod, Why are you not looking at Quick changes? straight from Winters catalog.
    trikejunkie likes this.
  12. 52Truckin
    52Truckin
    You mention axel flange to axel flange in your measurements of the A rear end. Is that the flange that the backing plates bolt on?
    -Brent- likes this.
  13. billfunk29
    billfunk29
    from Minnesota
    If you have the means, a V8 quickchange would fit.
  14. sdluck
    sdluck
    I bought a never used frankland qc that was 60 inches wide and offset,shorten long side axle and put a shorten axle in the long side came to 58 inch in my model a worked perfect.
  15. 1935ply
    1935ply
    from peyton,co
    So that post was from 2017, he might not notice your question. But most commonly flange to flange is where the wheels bolt to the axles.
  16. -Brent-
    -Brent-
    That's actually WMS (wheel mounting surface).
    1935ply likes this.
