Hot Rods Model A Build
Discussion in 'The Hokey Ass Message Board' started by rereaves, Mar 30, 2020.
  1. rereaves
    rereaves
    Can someone tell me what steering wheel attachment GM column utilized on 1969 and newer column. I need to fabricate a Steering Wheel Adapter which will go from my 3 hole attachment to the 69 and newer GM column attachment. I think the GM column utilized a single bolt and nut attachment but is it keyed or tapered? If someone knows of a adapter that will go from 3 hole attachment to GM attachment that would be great.
  2. alchemy
    alchemy
    Grant made adapters to put the standard three bolt wheels on everything.
    dana barlow likes this.
  3. goldmountain
    goldmountain
    I don't agree on alchemy's adapters for everything since I want an odd ball one for my OT car, but that one is a common one.
  4. rustydusty
    rustydusty
    They don't make one for a '50 Dodge. Had to fabricate a mount from the original steering wheel hub... 0201191600a.jpg 0211191428.jpg
  5. A Boner
    A Boner
    A friend had a “die cast“aftermarket adapter just turned to dust.....luckily he wasn’t at speed on the freeway!
  6. rereaves
    rereaves
    Thanks for your reply I will check it out. I have a three bolt column however the wheel I want to use is for a GM column therefore I need to purchase if I can find an adapter that will go from 3 bolt column to GM style wheel. If not I will make an adapter but I need the detail for a GM column, thread size length, taper if it applies or maybe it is keyed. Thanks again
  7. rereaves
    rereaves
    Gold mountain, nice looking wheel.
  8. alchemy
    alchemy
    Have you looked inside your GM steering wheel? You will probably see a bunch of splines in there.
    And I don't know what you are talking about when you say a 3 bolt column. The hot rod standard of a 3 bolt mounting system was not ever standard on a production car column. What is your column from?
  9. rereaves
    rereaves
    Sorry for confusion, I have a Speedway Hot Rod Column, this column has a quick disconnect designed for a 3 bolt wheel. The column is splined, the adapter is splined. For example Most of the Grant Wheels will bolt to the quick disconnect however I want a 1940 Delux Steering Wheel, to the best of my knowledge they all use a GM style attachment therefore I need the detail ***ociated with the GM column to make the adapter., example thread size, taper if it applies or if the column is keyed. , note I do not have the 40 delux wheel yet to reference. I want to keep the quick disconnect feature on my column if at all possible. Thanks again and hope I have not confused the request
  10. alchemy
    alchemy
    Original 40 wheels had a tapered and keyed shaft hole. Repros can be had like stock or with a new GM spline. Or, you can cut the bung off the back of your wheel, machine it flat, and drill 3 holes through it to bolt the wheel down on your removable disconnect with no adapter needed.
  11. rereaves
    rereaves
    Outstanding idea, I really appreciate the feedback. The wheel I'm looking at simply says "fits GM style Column". Think I will order wheel and make it fit.
