Model A carb ?????
Discussion in 'The Hokey Ass Message Board' started by slazzen, Jan 26, 2004.
  1. I got a down draft intake at the turlock swaps my motor is a stock 31 A motor can I run a 97 on it
  2. yorgatron
    yorgatron
    i don't see why not.ther's a guy down the street from who bought a 5 window that had a banger fitted with an ANSEN intake with a single holley 94 on top,it also has a mallory distributor.he bought it just for the body,but he won't sell me the frame and running gear because i won't give him what he thinks ($1500) it's worth.for that price he can keep it! you might wanna check out www.secretsofspeed.com they have some cool side covers and other neat stuff for good prices-george
  3. FORDY 6
    FORDY 6
    You can run the 97, might be to much fuel. A Stromberg 81 or Holley 92 would be better.
  4. Elrod
    Elrod
    Dual 97's on a Model A will be too much air and gas.
    [ QUOTE ]
    [/ QUOTE ]
    You could probably put that Ansen intake with carb, and mallory and sell it as a speed package for $600 - $800 on eBay these days. Shoot. If the Model A engine is running and has those items on it, you could probably get at least $2000 for the motor alone.
    I think you are passing up a reasonable deal at $1500, especially if it's running.
  5. the intake is a single zepher intake I have both 94s and 97s but no 81s or 92s
  6. Darwin
    Darwin
    Fordy 6 is right. A 97 is a bit much for a dead stock A motor . With a higher compression head and a mild cam it would be just right. You might just be able to properly use it with a head, Mallory dizzy and headers and leaving the internals alone. 2 97s would likely need a high comp. head, dizzy, headers and a stout cam with inserts and full oil pressure highly recommended. Headers would be necessary in any case 'cuz most downdraft intakes won't allow the use of a stock exhaust manifold.
  7. Bruce Lancaster
    Bruce Lancaster
    Something that has been done, not necessarily the hottest setup but certainly cheap: Mill or grind or file, depending on your technology/finance/time balance, a flat atop the stock manifold. Make it parallel to ground, not block.
    B manifold already has a nice flat that just needs cleaning. Make holes, put on 1950's adapter made to install Ford three bolt carbs to one barrel 6 cylinders.
    Cheap banger tech.
    Oh, don't forget to block off the old inlet down there...
  8. Elrod
    Elrod
    [ QUOTE ]
    [/ QUOTE ]
    Can you post a picture of your intake? I have a dual zepher intake, but have never seen a single zepher intake.
  9. how about a stromberg 48 will that work ??? this is a pic with a beat up 97 on it
  10. Elrod
    Elrod
    A stromberg 48 actually has a higher CFM than a 97. You're better off with the 97 if you are set on not running an 81.
    I will let you know that I do know a guy running a 97 on a single down draft intake similar to that, and he drives his Model A alot. It CAN be done, but may be overkill.
    Read this to learn more about strombergs....
    http://www.vintagespeed.com/newprod.htm
  11. 81s just cost alot but it looks like thats what i am gonna have to do man up some green
  12. FORDY 6
    FORDY 6
    The single Zepher seems to be fairly rare piece, I have duel. The Stromberg 48 pumps more air / fuel than the 97. 48 = 175 cfm with a 1.031 venturi. 97 = 150 cfm with a 0.969 venturi. 81 = 135 cfm with a 0.812 venturi. Issue V13 #3 Secrets of Speed has this info. If you can't find a copy or get it on the web site, PM me I'll copy the article.
  13. fordy 6 i tryed to get to the article but no luck send it to me please my e-mail is slazzen@astound.net any body got a 81 for sale ???
  14. yorgatron
    yorgatron
    Elrod,i have to assume you're on dope [​IMG] or something.first of all,this was NOT a running driving car,this was in-a-barn,frozen-engine,and mismatched wheels.second,ebay might be populated with idiots,but i'm not one of them.realistically i think a single 2bbl. intake with a 94 on top would probably go for $200-250 tops and a mallory dizzy shouldn't go for more than $100.i'd be doing this guy a favor if i hauled it off for $500,but that's just my opinion-george [​IMG]
