model a chop:beating a dead horse
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Nov 14, 2012.
  1. hotrodderhaag
    hotrodderhaag
    so,
    ive already done the search on all the model a chop threads.. seen lots of pictures. and there is a few different ways of doing it... im thinking about choping my 30 A, what is the best most proper way to do this..? just a straight 4 inch cut across the board, or stagger them in the rear corners and around the windows like i have seen done.
  2. jamesgs4
    jamesgs4
    from denver
    rule #1: ignore the people who tell you not to chop it.
  3. woodypecker
    woodypecker
    There were some good detail pictures in two recent issues of rod and custom.
  4. fuzzface
    fuzzface
    For just slicing thru the back window or around it depends on your preference of a full back window or a mail slot window.
  5. hotrodderhaag
    hotrodderhaag
    im chopping it, thats why i bought it, i have a bad problem not listenting to others,
    i just was curious to someone who has done it, what cut style works the best that everything ligns up the easiest, this will be my first,
  6. Midget25
    Midget25
    I don't believe there is an easier car to chop than a model A, just measure carefully,cut and weld. I like the little window,if you are chopping it you want it to look the part you know? Have fun, you will be fine.....................
  7. hotrodderhaag
    hotrodderhaag
    is this the best way?
    or this
  8. Rickybop
    Rickybop
  9. el Scotto
    el Scotto
    from Tracy, CA
    I prefer a straight 4" chopped Model A coupe.
    I did it this way:
  10. jamesgs4
    jamesgs4
    from denver
    the bottom pic, because it makes it easier to line up to weld,(if your lines are square)
  11. hotrodderhaag
    hotrodderhaag
    awesome! thanks guys.. appreciate it
  12. The bottom pic with the stagar.
    Its done that way because you will need relief cuts there anyway.
    If you prefer a lager back window, you can take some from below the window and less thru the window.
  13. Fenders
    Fenders
    There is a third way -- like the second pix but DON'T cut the center 3" -- cut across from the center of one 3" side to the center of the other, drop roof down, then cut across (cutting both pieces of metal), this cut need not be perfectly straight since the upper and lower will be cut the same and will align automatically...
    It ends up like the first photo but the cutting across needn't be as perfect.
    I don't have a photo or video but I'm sure someone does....
  14. Atwater Mike
    Atwater Mike
    The other thing to consider is the hinge on the A pillar: Some guys cut above and below, to locate the hinge at a more 'desireable' height?
    When you measure, you'll see what I mean. (2-1/2" chops don't consider this, they are cut below the hinge; but 4", that hinge will drop 4" if cut below. Just a consideration)
  15. scrap metal 48
    scrap metal 48
  16. Uncle Phil
    Uncle Phil
  17. slammed
    slammed
    KENNY BAKER aka CHOPRODS. Hook up with him. Mega talent.
  18. Mindover
    Mindover
    from England
    Just don't use a mig to weld it.
    David
  19. el Scotto
    el Scotto
    from Tracy, CA
    Why? I mig'd mine as well as thousands of other ***holes who welded up chopped tops in the 50's, 60's, and 70's.... Some of them even used OXYACETYLENE welders!!! :eek:
    Does it invoke the spirit of Giant Gila Monsters? 50 foot women? Dudes in piss yellow Deuce coupes? :D ;)
  20. Unkl Ian
    Unkl Ian
    I took an inch+ from below the rear window.
  21. hammered30
    hammered30
    from west aus
    When i chopped mine i staggered the cut. And i mig welded it up. Then friend of mine ran his shrinking disc over it. All it needed was a light skim of filler.
    Cheers hammered
  22. Cracked welds mostly. Slightly more devastating than piss yellow duece coupes. They're fine until you try to metal finish them. Mig & mud all day long but mig and hammer will give you an *** ache.
    Nobody mig welded a chop in the 50s. Probably not in the 60s either since the first practical
    Mig was patterned in 1962. Long time till it would see a body shop. Even longer before prices came down to far enough to be sold at Walgreens .
    Oxy acetylene is a great way to weld anything, even aluminum- just that others are faster and more practical.
  23. yekoms
    yekoms
    Hey Haag,
    Either way will work on a Model A. I chopped an A seadan straight across but chopped my (avatar pic) 34 coupe staggered. The 34 had curves in the roof that I didn't want to mess with and by droppin' the cut down from the middle of the window down to the belt line it stays away from the curves.
    Everything is pretty much straight down with an A except that the thickness is tapered on the sides at the window area.
    Smokey
  24. toreadorxlt
    toreadorxlt
    from Nashua, NH
    OA welding is actually better than MIG for chopping when done correctly because its a nice soft weld that you can hammer on and not worry about it cracking.
  25. hotrodderhaag
    hotrodderhaag
    I'm gonna tig mine. I think I'll do a straight across and slice the side windows and make it work that way .. I have seen soooo many hack jobs for a roof chop and there is no way in hell ill let mine fly that way. That's why I asked which was better . I get a lol nervouse about cutting my car up ha ha
  26. Mindover
    Mindover
    from England
    Well put, you knew what I was saying.
    just to be clear I have had a mig since 1982, I still have the same one and use it regularly just not for welding exterior panels where I can get to both sides of the panel.
    Tig or gas will give a weld with a lot less distortion. Mig welds are hard and very difficult to get anywhere near a metal finish. Gas is actually the quickest method of welding especially for ally but that is off topic here.
    People think that mig causes less distortion because it puts in very little heat, that is debatable but the main thing is that the weld is hard. Distortion is caused not so much by the amount of heat that is put into the weld but by how even or uneven that heat is. If a piece of metal is heated it expands when it contract it shrinks beyond its original state. If it is heated evenly it will expand and contract evenly so there will be little distortion. If it is heated unevenly (as is the case with mig skip welding) some places are heated more so expand and contract more causing distortion. Then if the weld is hard as it is with mig, dressing that distortion out is very difficult.
    Not knocking anyone, just trying to be helpful.
    David
  27. Boxcar's 1928
    Boxcar's 1928
    3" straight across is what I did...I did not have to move the top henge. When we welded it up....I'd recommend the initial welds secure the points around the edges of the openings...lining them up one by one from the back to the front. For a 3" chop, the top portion of the a piller will more than likely need some material added to match flush with the bottom (mine needed 1/16) or a guy could slice the bottom (maybe 4-5") both sides and push it in abit to line up the outside plane of the a piller. This accounts for small taper in that a piller.
    I look at my Signature link.....my chop is there
