Technical Model A chopped windshield frame
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Aug 23, 2018.
  1. Mike Colemire
    Mike Colemire
    Does anyone know where you can buy a frame already chopped 2 inches? I thought you could at Speedway but not for a closed car. I have a 28, 2 door, sedan with measurements of 12 1/4 tall, 45 3/4 top width, and 44 1/2 bottom width. That may vary some because they done a really poor job, I need to work on the windshield post and I ordered a new metal header that goes above the windshield.
  2. scrap metal 48
    scrap metal 48
    If you have the original frame and can get the top rail off, it's not to hard to do yourself.. From the top edge measure down 2 inches and cut at the same angle.. You also may want to move the tilt out brackets down a little so you can still tilt it out...
    dan31, 3340, lo c dan and 1 other person like this.
  3. If they done a really poor job, any pre-made frame from Speedway or anywhere else will likely have to be modified anyway. Chopping a windshield frame doesn't get much easier than a Model A. Then find a glass company that makes shower glass to cut your windshield.
  4. Mike Colemire
    Mike Colemire
    That is what I was afraid I was going to have to do. The one that came out of it is junk. They had it glued, siliconed, and welded. I liked to never got it out. I'll buy a new plain one and slice it I guess. I'll get the post straightened up and fit the new header and then measure for the cut. Thanks for the info.
  5. scrap metal 48
    scrap metal 48
    Most aftermarket frames are aluminum.. I believe Speedway's is....
    Dave Mc and lothiandon1940 like this.
  6. goldmountain
    goldmountain
    If you cut it yourself, you an make sure it fits properly. No two chops are exactly the same.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    lo c dan and Just Gary like this.
  7. goldmountain
    goldmountain
    I forgot to mention that I bought an aluminum windshield frame from speedway for my T coupe and there was a 5/16" gap from the windshield frame and the cowl so I had to compensate for this when I chopped it along with how much I took out from the header above it. If you cut it yourself, you can get it right.
    3340 and pitman like this.
  8. Mike Colemire
    Mike Colemire
    I've got to straighten up the windshield post, they are a mess, I'm going to look on Mike's A Fordable parts after while and see what he's got. I know he offers a kit for the swing out arms that includes everything pretty cheap. I had great service on the last order. I waited 3 days on Speedway to get back to me, suppose to be 1 to 2 days. I called today and 5 minutes after I hung up another guy called me from there. When I get ready to do this I may need advice on something, it'll be my first time at this.
  9. Mike Colemire
    Mike Colemire
    His are alum too. Do they weld good and finish back out to look ok?
  10. scrap metal 48
    scrap metal 48
    If the aluminum one is like the metal ones, you shouldn't have to weld it to chop it...
    lo c dan and lothiandon1940 like this.
  11. Torana68
    Torana68
    from Australia
    Fit the upper rubber seal when your checking the fit.
  12. sloppy jalopies
    sloppy jalopies
    Remember the W/S top is wider, you will need to spread the chopped ends out to match the top rail...
    don't cut the angles before you spread the sides out, it changes the angle, fit...
    use a goniometer [angle comparitor] to replicate the angle on the top to the sides after you have spread them...
    also changes the bottom corner angle so don't cut the gasket till the frame is bolted together...
    buddy uses the '30-'31 visors on '28-'29s, looks better and gives a little better traffic light vison...
    HIH.
    -Brent- and dan31 like this.
  13. Mike Colemire
    Mike Colemire
    Thanks, I didn't even think about that. That helps a lot.
