Model A column drop ? any idea if available?
Discussion in 'The Hokey Ass Message Board' started by lowsquire, Sep 14, 2012.
  1. lowsquire
    lowsquire
    from Austin, TX
    Hello all,
    Im trying to find one of the steering column drop extensions,that extend the standard drop down another inch and a bit.. I thought they were available as an aftermarket part, but arent having any luck searching for one. Anyone know if they are reproduced or if I am having a memory lapse about them ever being available?
    here is a link to a pic of one, aparently they were originally a Ford part on Victorias or some such..
    http://www.fordgarage.com/pages/steeringcolumndrop.htm
    Thanks for any leads!!
  2. walter
    walter
    Go over to the Ford Barn. The Model A guys over there have all the answers and are very helpful.
  3. Stovebolt
    Stovebolt
  4. lowsquire
    lowsquire
    from Austin, TX
    Thanks stovie! I'll check that out.
  5. Stovebolt
    Stovebolt
    You're welcome.
    These are a great idea if you're using a full size wheel.
  6. djust
    djust
    from Oklahoma
    I used Lime Works column, wheel and drop and love them all.
  7. turdytoo
    turdytoo
    I used a later 35-36 big truck column drop / lock in my '32. It was longer which allowed me to modify it to get the length and angle I wanted
  8. SoCal Merc
    SoCal Merc
    from SoCal
    I got my drop from maundspeed.com Nice piece. He is out of Pasadena, CA
  9. flatoutflyin
    flatoutflyin
    I made a bracket to lower my '36 MOPAR column drop about an inch and a half, and then made a sheet metal cover to hide the bracket and mount the ignition switch.
  10. B Ramsey
    B Ramsey
    do you have to do anything where the steering box mounts? enlarge holes or whatnot? i have an original drop id like to install later.
  11. Mr48chev
    Not sure about that. Here is the original mount in the link that Lowsquire posted in it's original form.
    This one is in my 31 Model A Victoria.
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    That pictured column mount has the spacer in it.
    The 31 column mount is bolted to the rail under the dash rail.
    Both spacer for the tank-mounted column mount and the 31 bolt on mount are available in the stocks of Model A Parts vendors across the continent.
  13. birdman42
    birdman42
    How about an old connecting rod cut the desired length?
  14. metal man
    metal man
    The original column mount is brazed and riveted to the tank. This piece is a bolt in to lower the column and not modify the tank.
  15. Bruce Lancaster
    Bruce Lancaster
    It is a spacer that drops the column slightly, originally used on the Model A tudor phaeton which had lower seats than most A's.
    For installation all it needs are longer bolts to hookitup to the standard drop.
    A lot of people like it in other A's but it has vanished from the repro catalogs.
  16. metal man
    metal man
    I like to change them to the later style mount that hangs the column from the pinch weld at the top of the tank, where it wont create a fuel leak.
  17. I used a stock column and stock drop with the key lock and switch from a '41 Ford. Made a bracket from square tubing that is flat on the bottom to take the drop and angled on the top to fit against the bottom of the roadster dash. Dropped the column about 1.5 " and works great...
  18. scrap metal 48
    scrap metal 48
    Limeworks sell what your looking for.. It's a 1 3/8" drop(aluminum) that bolts right in.. I think it sells for about $45.....
