Technical Model A Coupe decklid?
Discussion in 'Traditional Hot Rods' started by ty johnson, Dec 1, 2013.
  1. ty johnson
    ty johnson
    Does anyone have the opening measurements for a 29 coupe? My opening needs to be squared up a lil. It's out a bunch.
    Thanks,
    Ty
  2. classic gary
    classic gary
    i don't "have" them, but i can get 'em in the morning............
  3. olskool34
    olskool34
    Coming up........
  4. olskool34
    olskool34
    36 3/4 top opening, 35 5/8 bottom opening and a length (deck lid opening) of 31 inches. Taken off a un- restored car.
  5. ty johnson
    ty johnson
    Okay, thanks. What'd ya do, run out to the shop, peel the cover back, measure, then back in the house and post. Dang your fast. LOL Thanks for the measurements. The power of the HAMB!
  6. ty johnson
    ty johnson
    Ok, went out and measured mine. That's what i have, but if measure cross ways to X it out sorta speak, it's off. I'm 1/2" longer on one side. Gonna have to get out the porta power and push a lil here and there i think.
  7. olskool34
    olskool34
    That's exactly what I did!
  8. ty johnson
    ty johnson
    After several hours of beating, banging, pulling and pushing, i think i'm just going to make the skin fit the hole.
  9. olskool34
    olskool34
    Congrats. Glad I could help.
  10. mike bowling
    mike bowling
    If the diagonals measure a half inch different, the opening is half that dimension out of square. EG. if one diagonal is 41" and one is 41 1/2", the magic number is 41 1/4".I just had the same problem with a coupe, and pushed the rear quarters around a little, then added small pieces of curved to fit 1/8" flatstock with weld build-up to the opposite corners of the decklid to make the reveals more pleasing to the eye.It's a give and take thing, and I don't think these old buggys were square to begin with! Good luck. Mike
  11. ty johnson
    ty johnson
    Oh i know this thing's not square. LOL I've been doing all the other stuff and saving it for last for now. Thanks for the input Mike.
    Ty
  12. fordcragar
    fordcragar
    from Yakima WA.
    In a situation like this, the first steps would be to find out where it is out of square. Using a tape measure, check the subframe for square. If this is square, then the place to check would be if the upper part of the trunk opening is square to the floor, via some cross measurements. Sometimes it doesn't take much movement to create opening problems.
  13. ty johnson
    ty johnson
    I'm a bodyman/painter by trade. When i'm ready i'll get the port-a-power out and make it square.
  14. d-rod!
    d-rod!
    I'm a 30 year bodyman , I have a 31 coupe , mine was also out of square so I made my lid fit the hole , pie cut the side that was out and cut till the gap was good , nobody will ever notice, good luck
