Hot Rods Model a coupe dimensions
Discussion in 'The Hokey Ass Message Board' started by pompadour, Jul 15, 2008.
  1. pompadour
    pompadour
    i have been searching for a dimension all over the hamb i found dimensions for a 28-9 and 30-1 but it only shows the inside cabin dimension...i need the dimension from the outside to outside of the rear wheel wells w/ no fenders..can someone point me in the correct direction or take a stroll out to your garage and give me a hand..thanks matt
  2. ridin dirty
    ridin dirty
    I need the same . Just picked up a 30 coupe that need alot of work .
  3. Russco
    Russco
    from Central IL
    Try Wescotts site they have frame dimensions that should get you pretty close
  4. pompadour
    pompadour
    i need the body dimensions...i have the frame dimensions already....i want to know what they are so i can get mine close
  5. Use the search, there is a couple of threads that have links
  6. pompadour
    pompadour
    i did search but i never found this dimension...i have found side shots of the cars and all there dimensions but only one width dimension of the inside on the cabin...i have the frame dimensions but i still need this one.....any help would be great
  7. pompadour
    pompadour
    could i go off the width of the rear crossmember roughly
  8. 43.25" between wheel wells on a 30-31, outside dimension.
  9. pompadour
    pompadour
  10. Look in the tech section under CAD scans by Paul, there are a few
    scans there that have all the info you need
  11. Scott
    Scott
  12. pompadour
    pompadour
    i have seen them and studied them but they dont give any body widths only frame and body length...only 1 measurement for the inside of body
